i bought a cal-trac mono spring,and bar set up...(for a b+e) a few swaps ago.got it pretty cheap,and was going to use it on my charger,but never did.so i am now working on my dart,and want this set-up under it...so what is different?..can i buy the shorter front spring segment?...and also can i buy the tube that is shorter for the a-body? i was just wondering if anyone knows about going from a b+e setup,to a a-body setup,and maybe an idea of the cost for the spring,and tube?....sure would be nice if i can. i already have a new d-60 narrowed,w/disc's from mosier,,,thinking the cal-trac would be perfect addition...so anyone?? thanks,in advance..mike
