Re: Braided line for master cyl. to prop valve. Acceptable?
[Re: 340_Dart]
#1377611
01/28/13 05:56 PM
01/28/13 05:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its acceptable but the more braided you use the spongier the pedal feels (I ran braided line for the whole brake system but I dont like it, I will change it over to steel line)... for as easy as it is to bend up the steel I would go with the steel
[Re: MR_P_BODY]
#1377612
01/28/13 07:17 PM
01/28/13 07:17 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I don't know if there is different grades of the braided brake line or not...but my 05 Durango had braided lines from the master cylinder into the ABS module, and the pedal felt fine.
I agree that the more braided you have the spongier the pedal can feel, but I also don't think a few inches will make a huge difference. look at how long the lines are from the frame to the rear axle, and from the frame to the front calipers, what's a few more inches going to do?
**Photobucket sucks**
[Re: 70Cuda383]
#1377613
01/28/13 08:29 PM
01/28/13 08:29 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
Use the line made for brakes and are lined with teflon
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1377615
01/28/13 09:34 PM
01/28/13 09:34 PM
Challenger 1
Cincinnati, Ohio
They still flex and can cause soft petal, even short pieces can.
[Re: beezer]
#1377616
01/28/13 09:41 PM
01/28/13 09:41 PM
Challenger 1
Cincinnati, Ohio
I had steel line going side to side on my dragster but thought the braided line line looked better, so I changed it. Used the braided line meant for brakes with the teflon lining. My hand brake never got hard and you could watch the braided actually expand when the brakes were applied. The steel line went back on the following week.
Me too, I experienced the same thing years ago.
[Re: Challenger 1]
#1377617
01/28/13 11:35 PM
01/28/13 11:35 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I made some -3 lines from my MC to prop valve along time ago. I noticed no difference in pedal really. Its been that way for 8-10 years now.
68 Barracuda Formula S 340
[Re: Crizila]
#1377620
01/29/13 09:23 AM
01/29/13 09:23 AM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
The braided part of a braided line does little ( if any ) control of the line expansion under pressure. It's just a protective cover from external abraision.
this is absolutely false. the braid is an integral reinforcement to the teflon lining. brake lines work at a few thousand psi and teflon itself would not hold up. the braided brake lines are different than the braided fuel lines. the fuel line braid is there for aesthetics and abrasion resistance. the brake line is braid is there for strength. that being said there are various braided hoses manufacturers and having tested most there is a wide difference in quality between them. the braid needs to be flexible but tight on the core and some of the hoses we worked on had double braided layers.
hoses are designed to move when the braid packages are considered they are designed to swell and shorten as well as some amount of twist is acceptable. this is fine when used in a hydraulic system. its not fine when your using it in a brake system with a limited amount of pedal travel and master cylinder piston/stroke volume.
For those that had a the spongy pedal i would surmise that the extra volume added by the hoses was identifying the limit of the master cylinder if you went with a larger bore master the spongyness would go away, again this a guess, and would need to be tested. as with all engineered hydraulic systems it is important to consider the entire system when selecting parts, most racers don't and very few people actually understand hydraulics.
[Re: Jerry]
#1377626
01/29/13 04:58 PM
01/29/13 04:58 PM
Posts: 7,506 Az
Crizila
Az
You are absolutely right. I ment to refer to the steel outer jacket ( abraision ) not the braided layer just outside the teflon liner. That being said, Braided line, not matter who the manufacturer, will expand under pressure. The more of it you use, the more pressure loss will occur when peddle pressure remains constant. Sure, you can overcome the loss by adding more peddle pressure, but you will lose some feel and end up with a spongier feeling peddle. Adding more fluid by going to a bigger master bore sure as hell isn't the answer. Other drawbacks include $$$ and about twice the diameter of steel line - gee, I wonder why?
Fastest 300
