69 B Body ignition relay #1376787
01/26/13 10:42 PM
01/26/13 10:42 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Can someone please post a pic of the corect ignition relay for a 1969 GTX, 440, 4 speed.
Re: 69 B Body ignition relay [Re: frank] #1376788
01/27/13 12:26 AM
01/27/13 12:26 AM
N
NITROUSN Offline
NITROUSN  Offline
N
What exactly are you looking for? There is no ignition relay.
Re: 69 B Body ignition relay [Re: frank] #1376789
01/27/13 02:29 AM
01/27/13 02:29 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I am guessing you are looking for the starter relay. Part# for a 1969 4spd car is 2444453. As you probably already know, the relay for an auto trans car has one more terminal than the 4 spd relay. A Google search found the one below and others.
http://www.billrolikenterprises.com/proddetail.asp?prod=2444453-179
Re: 69 B Body ignition relay [Re: moparfan53] #1376790
01/27/13 02:56 AM
01/27/13 02:56 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
What is the extra terminal for on the automatic?
Re: 69 B Body ignition relay [Re: A12] #1376791
01/27/13 03:36 AM
01/27/13 03:36 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
...What is the extra terminal for on the automatic?
It is connected to the neutral safety switch to prevent starting in gear. The auto relay can be used on a 4spd car, it just doesn't look "correct" because of the unused terminal. This may be why the OP is looking for a pic. Also, IIRC Chrysler eventually superceded the 4spd relay to the auto one.
Re: 69 B Body ignition relay [Re: moparfan53] #1376792
01/27/13 03:42 AM
01/27/13 03:42 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You need to ground the unused terminal... No ground=No start...
Re: 69 B Body ignition relay [Re: 1_WILD_RT] #1376793
01/27/13 05:13 AM
01/27/13 05:13 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I guess you could cut and grind the extra terminal and then do an internal ground or spend $65.00 for one that looks like that's been done with a big glob of soldier
The one on my 4-speed '69 GTX is an auto one that someone ran a ground wire to when I first got it, now I know why THANKS! I think I'll do an internal ground and let you know how and if it worked.
Re: 69 B Body ignition relay [Re: 1_WILD_RT] #1376794
01/27/13 11:02 AM
01/27/13 11:02 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
...You need to ground the unused terminal... No ground=No start...
1_WILD_RT, Thanks for the correction/clarification to my post.
Re: 69 B Body ignition relay [Re: A12] #1376795
01/27/13 11:14 AM
01/27/13 11:14 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
...guess you could cut and grind the extra terminal and then do an internal ground or spend $65.00 for one that looks like that's been done with a big glob of soldier
There is quite a price range on ebay, lowest one is $17.50 + $5 shipping.
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=2444453&_sacat=0&_from=R40
Re: 69 B Body ignition relay [Re: frank] #1376796
01/27/13 12:24 PM
01/27/13 12:24 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Yes. Starter relay. Thanks for the info. This is what I took off the car. I thought it was an original part but I was not sure.
Re: 69 B Body ignition relay [Re: frank] #1376797
01/27/13 01:13 PM
01/27/13 01:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The one with the extra long bracket is a C body version.
1969 B-body with manual trans is the one on the lower right
