Re: 69 B Body ignition relay
[Re: A12]
#1376791
01/27/13 03:36 AM
01/27/13 03:36 AM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
...What is the extra terminal for on the automatic?
It is connected to the neutral safety switch to prevent starting in gear. The auto relay can be used on a 4spd car, it just doesn't look "correct" because of the unused terminal. This may be why the OP is looking for a pic. Also, IIRC Chrysler eventually superceded the 4spd relay to the auto one.
![](/ubbthreads/images/graemlins/beer.gif)
[Re: 1_WILD_RT]
#1376793
01/27/13 05:13 AM
01/27/13 05:13 AM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
You need to ground the unused terminal... No ground=No start...
I guess you could cut and grind the extra terminal and then do an internal ground or spend $65.00 for one that looks like that's been done with a big glob of soldier ![](/ubbthreads/images/graemlins/blush.gif)
The one on my 4-speed '69 GTX is an auto one that someone ran a ground wire to when I first got it, now I know why THANKS! I think I'll do an internal ground and let you know how and if it worked.
[Re: 1_WILD_RT]
#1376794
01/27/13 11:02 AM
01/27/13 11:02 AM
moparfan53
NB, Canada
...You need to ground the unused terminal... No ground=No start...
1_WILD_RT, Thanks for the correction/clarification to my post. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: A12]
#1376795
01/27/13 11:14 AM
01/27/13 11:14 AM
moparfan53
NB, Canada
...guess you could cut and grind the extra terminal and then do an internal ground or spend $65.00 for one that looks like that's been done with a big glob of soldier ![](/ubbthreads/images/graemlins/blush.gif)
There is quite a price range on ebay, lowest one is $17.50 + $5 shipping.
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=2444453&_sacat=0&_from=R40
