Weight loss - hood or heads? #1375534
01/25/13 04:48 PM
01/25/13 04:48 PM
Santa Cruz, California
Lefty Offline OP
Lefty  Offline OP
66 Coronet with a 440 and 516 ported factory heads - Any ideas on a front end weight loss program that drops the most weight? Comparing stock steel to lift off fiberglass hood or stock steel to aluminum heads. Which change would lighten the front end the most?
I'm going to do both, but can afford only one at a time.
Re: Weight loss - hood or heads? [Re: Lefty] #1375535
01/25/13 05:16 PM
01/25/13 05:16 PM
fullmetaljacket Offline
Cheapest: Hood.
Expensively, but done the right way: Heads.
Both about the same weight in removal with the heads maybe nudging heavier on the scale by a little. Usually both steel heads will be at about 110 pounds. where as a steel hood will be at about 70 or so.
Re: Weight loss - hood or heads? [Re: Lefty] #1375536
01/25/13 05:21 PM
01/25/13 05:21 PM
Sterling Hts, MI
2
2FASTCORONET Offline
Sterling Hts, MI
Fiberglass hood, bumper, aluminum heads, water pump housing and pump, aluminum radiator, plastic/metal master cylinder, lose the wiper motor
Re: Weight loss - hood or heads? [Re: 2FASTCORONET] #1375537
01/25/13 06:09 PM
01/25/13 06:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Fiberglass hood = weight loss.
aluminum heads = weight loss + horsepower
I know what I would do.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Weight loss - hood or heads? [Re: pittsburghracer] #1375538
01/25/13 06:20 PM
01/25/13 06:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My opinion also... thats a 2 for 1
Re: Weight loss - hood or heads? [Re: MR_P_BODY] #1375539
01/25/13 07:27 PM
01/25/13 07:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Take into account painting for the hood, and any upgrades/corrections needed on the heads. Hood's gonna be cheaper, heads are most likely a two-fer depending on your combo & porting.
Re: Weight loss - hood or heads? [Re: Lefty] #1375540
01/25/13 07:51 PM
01/25/13 07:51 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Stealth heads,water pump/housing,radiator- all aluminum = 60 lbs off the front of my car.
Nautilus Racing-
Re: Weight loss - hood or heads? [Re: pittsburghracer] #1375541
01/25/13 08:03 PM
01/25/13 08:03 PM
True this.
If you have the budget and pretty sound motor, I would go with the heads as well. Factor in the rockers, etc. and it could be a little pricey as compared to a Hood though. Some good rattle can satin black will paint it for the moment.
Re: Weight loss - hood or heads? [Re: Chris2581] #1375542
01/25/13 08:03 PM
01/25/13 08:03 PM
Renton Washington
Triple Threat Offline
Renton Washington
Been there, done that. I chose heads and am happy I did!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Weight loss - hood or heads? [Re: Lefty] #1375543
01/25/13 09:23 PM
01/25/13 09:23 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
steel duster hood 50lbs fiberglass duster hood 12lbs
alloy heads are another 50lb, an alloy radiator saved me a bunch over a factory one and also I saved a further 50lb by upgrading to areospace front brake set.
Re: Weight loss - hood or heads? [Re: Lefty] #1375544
01/25/13 09:30 PM
01/25/13 09:30 PM
Washington State, USA
W
Winchester 73 Offline
W
dont forget you can always race without the hood on!its free!
Re: Weight loss - hood or heads? [Re: Winchester 73] #1375545
01/26/13 05:01 AM
01/26/13 05:01 AM
sweden
sshemi Offline
sshemi  Offline
sweden
If the hood had a scoop you would also get cooler air to the motor.
Re: Weight loss - hood or heads? [Re: sshemi] #1375546
06/22/13 02:17 AM
06/22/13 02:17 AM
Lefty Offline OP
Lefty  Offline OP
Ok, been working way too hard to pay for a serious weight loss. You guys were about 50/50 on hood or heads so I bought a set of heads and am ordering a AAR lift off hood tomorrow. Next on the list is venting some of the under hood air build up with bolt on louvers and an air dam to keep too much air from getting under the car. Anyone know if louvers on the hood will "suck" hot air from the engine compartment due to air flow over the louvers?
Re: Weight loss - hood or heads? [Re: Lefty] #1375547
06/22/13 04:14 AM
06/22/13 04:14 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
....just a FYI ....if you are ordering an AAR brand hood for a weight-reduction ...in many cases ..... forgetaboutit !!
At least in most cases ....uNless you can get their promised net weight of the part IN WRITING when you order the part. Many MANY times it has been reported that their fiberglass hoods are VERY CLOSE to what a steel part weighs. And on bolt-on hoods sometimes way-OVER what a steel hood weighs.
So BE aware ....
Re: Weight loss - hood or heads? [Re: dOc !] #1375548
06/22/13 09:18 AM
06/22/13 09:18 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Fiber glass heads.
Re: Weight loss - hood or heads? [Re: Bill MeLater] #1375549
06/22/13 01:29 PM
06/22/13 01:29 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Carbon Fiber glass heads.
Mo' Farts
Moderated by "tbagger".
Re: Weight loss - hood or heads? [Re: Lefty] #1375550
06/22/13 01:47 PM
06/22/13 01:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hood, I have my stock hood hanging on the wall. The new race weight glass hood is probably 50lbs lighter.
Coming soon!!!!
Re: Weight loss - hood or heads? [Re: Mr.Yuck] #1375551
06/22/13 01:50 PM
06/22/13 01:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
also depending on what head you pick you might be dropping a full point of compression 516's have about 76cc champer or less.
Re: Weight loss - hood or heads? [Re: dOc !] #1375552
06/22/13 09:19 PM
06/22/13 09:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
So BE aware ....
Do you have an example?
The bolt on AAR 6 pack hood on my Dart is about 31.3lbs lighter than the stock flat hood.
Re: Weight loss - hood or heads? [Re: dOc !] #1375553
06/23/13 12:50 AM
06/23/13 12:50 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So BE aware ....
Is this new since they have been taken over? My Dakota hood was a bolt on and was a lot lighter then stock.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
