Re: Weight loss - hood or heads?
[Re: Lefty]
#1375535
01/25/13 05:16 PM
01/25/13 05:16 PM
fullmetaljacket
Cheapest: Hood.
Expensively, but done the right way: Heads.
Both about the same weight in removal with the heads maybe nudging heavier on the scale by a little. Usually both steel heads will be at about 110 pounds. where as a steel hood will be at about 70 or so.
[Re: 2FASTCORONET]
#1375537
01/25/13 06:09 PM
01/25/13 06:09 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Fiberglass hood = weight loss. aluminum heads = weight loss + horsepower I know what I would do.
[Re: pittsburghracer]
#1375538
01/25/13 06:20 PM
01/25/13 06:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My opinion also... thats a 2 for 1
[Re: Lefty]
#1375540
01/25/13 07:51 PM
01/25/13 07:51 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Stealth heads,water pump/housing,radiator- all aluminum = 60 lbs off the front of my car.
[Re: Lefty]
#1375547
06/22/13 04:14 AM
06/22/13 04:14 AM
Posts: 30,465 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
and am ordering a AAR lift off hood tomorrow.
....just a FYI ....if you are ordering an AAR brand hood for a weight-reduction ...in many cases ..... forgetaboutit !!
At least in most cases ....uNless you can get their promised net weight of the part IN WRITING when you order the part. Many MANY times it has been reported that their fiberglass hoods are VERY CLOSE to what a steel part weighs. And on bolt-on hoods sometimes way-OVER what a steel hood weighs.
So BE aware ....
[Re: dOc !]
#1375552
06/22/13 09:19 PM
06/22/13 09:19 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
So BE aware ....
Do you have an example?
The bolt on AAR 6 pack hood on my Dart is about 31.3lbs lighter than the stock flat hood.
