Quickfuel vs Proform vs Holley??? #1375376
01/25/13 11:57 AM
01/25/13 11:57 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I need to buy a new base plate for my 750 dp
What brand should I go with. There is a seller on Ebay that will sell me a new quick fuel billet piece for $100- the cost of the cast Holley one. Are quick fuel base plates any good, or should I stick with genuine Holley parts?
Re: Quickfuel vs Proform vs Holley??? [Re: mopowers] #1375377
01/25/13 01:51 PM
01/25/13 01:51 PM
tucson az
frank Offline
frank  Offline
tucson az
I don't know about a base plate, but the last carb I bought I went with Proform. I have no regrets. it's a quality carb at a good price. I'll buy another when the time comes.
Re: Quickfuel vs Proform vs Holley??? [Re: mopowers] #1375378
01/25/13 01:52 PM
01/25/13 01:52 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm just curious if my Holley main body will line up correctly with a proform or quick fuel base plate.
Re: Quickfuel vs Proform vs Holley??? [Re: mopowers] #1375379
01/25/13 02:13 PM
01/25/13 02:13 PM
PA
noplanb Offline
noplanb  Offline
PA
I put a Quickfuel billet throttle plate on a 950 HP. It works fine, but I ended up reusing all the linkage hardware - everything didn't just bolt right on.
Expect to do a little fiddling, but it fits and works great.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Quickfuel vs Proform vs Holley??? [Re: noplanb] #1375380
01/25/13 03:28 PM
01/25/13 03:28 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for the input! What do you mean everything didn't just bolt on? Were things misaligned? bolt holes to small? I'm looking for a bolt on base plate to replace my messed with Holley one.
Re: Quickfuel vs Proform vs Holley??? [Re: mopowers] #1375381
01/25/13 03:32 PM
01/25/13 03:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Use the base plate you have, put a #4 bolt in the hole in the throttle plate, nut on the other side, bolt just long enough to leave a couple threads visible which you can peen down so the nut can't back off....
Re: Quickfuel vs Proform vs Holley??? [Re: 1_WILD_RT] #1375382
01/25/13 04:41 PM
01/25/13 04:41 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
That would fix the throttle plates, but I still need to find a 3/8" hose nipple to thread into 1/8 NPT threads where the old PCV nipple was pressed in. The guy who ran this carb, tapped and plugged it. I also need to divide the grooves that connect the primary and secondary idle circuits with some JB weld and file them flat. I'd almost rather buy a new base plate with tight throttle shafts that I don't have to do any work on. ya know? I'll likely try to run what I've got first though because I tend to learn the hard way...
Re: Quickfuel vs Proform vs Holley??? [Re: mopowers] #1375383
01/25/13 05:00 PM
01/25/13 05:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
The proform and qft are the same base plate just anodized different colors...either one will fit your 750 dp...I have to holley 750 with the proform base plates..
Tony
70 AARCuda Vitamin C
Re: Quickfuel vs Proform vs Holley??? [Re: mopowers] #1375384
01/25/13 05:07 PM
01/25/13 05:07 PM
PA
noplanb Offline
noplanb  Offline
PA
I have the secondary idle speed screw adapter, and the new secondary shaft wasn't long enough for it on the pass side. So I reused the original shaft and the linkage, and the throttle blades IIRC.
Nice piece, no other issues.
Re: Quickfuel vs Proform vs Holley??? [Re: noplanb] #1375385
01/25/13 06:27 PM
01/25/13 06:27 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Aren't the proform and quick fuel plates already modified for the secondary idle speed adjustment?
Re: Quickfuel vs Proform vs Holley??? [Re: mopowers] #1375386
01/25/13 08:42 PM
01/25/13 08:42 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
I buy all my carb stuff from www.allcarbs.com I find them excellent to deal with and their tech support is also excellent.
I brought a QF base plate for my 780vs and one for my 950hp, both fitted and lined up perfectly, out of the two carbs the 780vs has inproved better with allstates parts and tech recommendations
Re: Quickfuel vs Proform vs Holley??? [Re: SG duster] #1375387
01/25/13 10:36 PM
01/25/13 10:36 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am a QuickFuel guy based on price and quality. Holley is coming around but their components are still a little high for my taste.
Re: Quickfuel vs Proform vs Holley??? [Re: Jeremiah] #1375388
01/26/13 01:57 AM
01/26/13 01:57 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes
Tony
