Page 1 of 3 1 2 3
first 440's #1375257
01/25/13 01:24 AM
01/25/13 01:24 AM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
What year did they first make the 440's, and which year is the best
(68 440 magnum ?)
Re: first 440's [Re: 340mouse] #1375258
01/25/13 01:34 AM
01/25/13 01:34 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
first 440 was 66 model year... Best? maybe 67 with the 915 heads.. Or 69 with the LY rods & 6bbl....
Re: first 440's [Re: 340mouse] #1375259
01/25/13 02:16 AM
01/25/13 02:16 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What do you mean by BEST ??
Re: first 440's [Re: 340mouse] #1375260
01/25/13 03:38 AM
01/25/13 03:38 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I hope this seems relevant to the question and isn't hijacking the thread. I have been wanting to ask this; I remember hearing some 440's were prone to overheating. Was this a particular production year and what was the cause. Thanks!
Facts are stubborn things.
Re: first 440's [Re: 340mouse] #1375261
01/25/13 03:42 AM
01/25/13 03:42 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
(68 440 magnum ?)
If by "best" you mean which put out the most power in stock form, that would be the 1970 440 six pack. If by "best" you mean which is the preferred year engine block to build, that's a crapshot. None are really any better than the next. Only way to know is to have your block checked out by a machine shop.
None more than any other. 440 never really changed much. Head design changed a bit and compression ratios went up and down but other than that no real remarkable changes to the block, only stuff that really changed was the bolt on stuff.
Re: first 440's [Re: DaytonaTurbo] #1375262
01/25/13 06:54 AM
01/25/13 06:54 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
There was a stiffening rib added to the lwr rh side of the block at around 1969. The #3 main bearing was machined for a larger trust surface in the mid 70's (1973?). Then there's the larger cooling passages added, known as the "figure 8" as seen by the bigger passages/port at the cylinderhead deck surface. Most importantly is the varying amount of cast iron at the "saddle support area".............
OR, just go here and read all about it..........
http://www.440source.com/blockinfo.htm
Re: first 440's [Re: Dean_Kuzluzski] #1375263
01/25/13 07:55 AM
01/25/13 07:55 AM
ScatPackNick Offline
Nice link, bookmarked it.
Re: first 440's [Re: 340mouse] #1375264
01/25/13 11:28 AM
01/25/13 11:28 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Any 440.
452 heads.
Period. End of story. Move on folks. Nothing more to say here.
Re: first 440's [Re: Commando1] #1375265
01/25/13 01:08 PM
01/25/13 01:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Any 440.
452 heads.
Other than Wrong! I have no use for 452 heads....
Re: first 440's [Re: larrymopar360] #1375266
01/25/13 02:44 PM
01/25/13 02:44 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
its more like
bb cars that had 22' radiator openings
were more prone to overheating.
just take the shroud off and you would start to have problems..
Re: first 440's [Re: flypaper] #1375267
01/25/13 04:13 PM
01/25/13 04:13 PM
dogdays Offline
dogdays  Offline
I don't recall, back in the day, any 440 overheating stories, but then again back in the day, cars with 440s in them had been built that way.
Here's what I think: If I was looking for a 440 I would grab the first block with standard bore that was available at a reasonable price.
Now as far as heads go, for stock heads on a 440 the 452s are out there, they flow like any other '68-and-up B/RB head, also have the same crappy combustion chamber design, but they have hardened seat areas and are easier to home port. The second you start paying someone to port a set of cast iron heads you should stop, think twice and go directly to 440Source, Edelbrock or MP. Those aluminum heads are much better and the cash outlay won't be more than you'd pay a decent porter to work on your 30+year-old cast iron heads.
If you can do most of the porting yourself there's no reason not to use the iron heads especially if you're just building a hot street motor. But the minute you get into horsepower wars, those iron heads have to go. That's unless you are required to use them by class rules.
R.
Re: first 440's [Re: 340mouse] #1375268
01/25/13 04:57 PM
01/25/13 04:57 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I agree with most of the others;
- "best" is subjective and without clarification, unanswerable...at least logically. best block? best engine assy? is the highest hp best?
- all 440 blocks are substantially the same; changes in blocks year to year are negligable, especially for most uses.
- Though there are certainly advantages and disadvantages to various 440 heads, it's kinda like arguing which fat chick is going to win the bikini contest...and you can make decent power with any of them though Dogdays advice on the available aftermarket heads should be heeded IMO.
Unless you care about casting dates and HP stamps, I'd use any 440 block that was in good shape. I would stick with a forged crank though it isn't strictly required and depending on budget, I'd either use any muscle-era 440 head or an Eddy or Stealth set. A painted stealth set for a stock appearing street engine would be my first choice.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: first 440's [Re: DPelletier] #1375269
01/25/13 07:04 PM
01/25/13 07:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And here is my reason for liking the 915 head.. Granted it gives up port flow to the aluminum offerings Plus it won't take as much compression as the aluminum heads.... But lots of guys have a shortblock that was built with the piston .018-.024 in the hole... My 383 is like that... If you use a closed chamber head (915) & a .021 steel shim head gasket that puts you at .039-.045 piston to head.. Ideal quench.. But you can't run an aluminum head with a steel gasket so the typical comp gasket is .039 + .018-.024 makes quench .058-.063... Detonation central....
Re: first 440's [Re: 1_WILD_RT] #1375270
01/25/13 07:23 PM
01/25/13 07:23 PM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
I'm not disagreeing with anything you just said, but how is it going to be "detonation central" with less compression and better heat dissipation?
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: first 440's [Re: BMChrysler68] #1375271
01/25/13 07:43 PM
01/25/13 07:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Fifteen years ago I built a 340 with 10.4 C/R, aluminum heads & .070 piston to head clearance... It would detonate with more than 28-30 degrees total timing... I wound up pulling the heads & cutting them .030, it raised the C/R to 11.2 but the engine no longer detonates & it is running 36 degrees advance....
Read this..
http://www.kb-silvolite.com/article.php?action=read&A_id=39
Re: first 440's [Re: 1_WILD_RT] #1375272
01/25/13 08:27 PM
01/25/13 08:27 PM
DPelletier Offline
DPelletier  Offline
I'm sure you're correct. My point was that all things being equal (i.e. identical compression using, different gaskets, shaving the heads, different CH pistons or whatever) that one cast iron Mopar 440 head isn't going to make a bunch more power than another cast iron Mopar 440 head. Of course MW heads are somthing else.
It's not like oval port vs. rectangular port BBC heads, or RAIV vs. standard poncho 400 heads, or W30 vs. regular 442 heads, or LT1 heads vs. 350 2bbl heads or ...well, you get the idea; Mopar stuff is nice in that you don't need the exotic stuff to get your base engine up to the same level as the HP models.
Re: first 440's [Re: DPelletier] #1375273
01/25/13 09:57 PM
01/25/13 09:57 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I guess the ultimate 440 with stock parts would be to use the thickest wall stock bore block you could find (any year), big valve 915 heads, non HP rods, any year forged crank, 70-71 HP pistons, 69 six pack intake with a set of six pack carbs that didn't have sticking problems, oh and a 73 electronic distributor as well as a 3 bolt drive Six Pack spec camshaft with matching double roller, windage tray and 70-71 HP oil pan.
Sheldon
Re: first 440's [Re: RUNCHARGER] #1375274
01/25/13 10:00 PM
01/25/13 10:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Sheldon
Just about right !!
Re: first 440's [Re: 62maxwgn] #1375275
01/25/13 10:12 PM
01/25/13 10:12 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I'd venture that the best "stock" 440 was the 69.5 Roadrunner (with the Bauman-prepped carbs & God knows what else) that Ronnie Sox ran for magazine exposure when the A12 cars were introduced.
Re: first 440's [Re: 1_WILD_RT] #1375276
01/25/13 10:28 PM
01/25/13 10:28 PM
Manitoba, Canada
Manitoba, Canada
Some guys do run the steel shim gaskets with the aluminum heads. Also IIRC cometic makes a very thin composite gasket as well.
Page 1 of 3 1 2 3
