cnc or hand port job 440-1 #1375189
01/24/13 10:25 PM
01/24/13 10:25 PM
nc
E
earthmover Offline OP
E
nc
going to have my 440-1s done who what and why is the ?????right now they are on my 451 but plan on a bigger ci later on this year if things work out maybe a 512 not sure but would like to get all I can get..
Re: cnc or hand port job 440-1 [Re: earthmover] #1375190
01/24/13 11:21 PM
01/24/13 11:21 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Scott Brown did my 440-1's
with a "street" roller cam, my car is right there with combinations that have more cam and lighter weight,
I have been 5.40's at 3500 and first time out at 3330 the car went 5.30's Im sure a little more nitrous or tuning will put the car in the 20's
....BAD A$$ STREET CAR.....
Re: cnc or hand port job 440-1 [Re: n20mstr] #1375191
01/25/13 12:14 AM
01/25/13 12:14 AM
nc
E
E
nc
thank you .. any contact info for him??? would be great
Re: cnc or hand port job 440-1 [Re: earthmover] #1375192
01/25/13 02:04 AM
01/25/13 02:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dwayne Porter did some work on my EZ heads for me and it is exellent work. He did hand porting as he is one of the best there is. I dont think he has a CNC machine. Ron
Re: cnc or hand port job 440-1 [Re: earthmover] #1375193
01/25/13 02:34 AM
01/25/13 02:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Send them to Jeff at Modern to have them CNC
Re: cnc or hand port job 440-1 [Re: earthmover] #1375194
01/25/13 10:09 AM
01/25/13 10:09 AM
an8sec70cuda Offline
I'd send them to Dwayne Porter at Porter Racing Heads. He did an outstanding job on my Indy SR heads...he's pretty good a spec'ing cams too.
If you want them CNC'd, send them to Jeff at MCH.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: cnc or hand port job 440-1 [Re: earthmover] #1375195
01/25/13 09:38 PM
01/25/13 09:38 PM
N
n20mstr Offline
n20mstr  Offline
N
buyracingparts.com
there is a contact info part on there were you can send him an email.
whats your car weigh? im 3330, so you can get an idea of how fast you will go....
Re: cnc or hand port job 440-1 [Re: n20mstr] #1375196
01/25/13 09:52 PM
01/25/13 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
buyracingparts.com
As far as I know Scott never did any porting himself...
when I got my B1M/C heads from him he suggested sending
them to Modern and I did... he use to use a guy named
Duane up our way here for port work
Re: cnc or hand port job 440-1 [Re: MR_P_BODY] #1375197
01/25/13 11:52 PM
01/25/13 11:52 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Best bet? send them to someone like Modern for cnc. Then to someone like Porter to have them finished off for your combination. Been there done that. Just gets you the best there is.
Re: cnc or hand port job 440-1 [Re: Cuda367] #1375198
01/26/13 08:00 AM
01/26/13 08:00 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Any contact info for Dwayne Porter?Tried to google it and it came up
http://supercarraces.com/Porterracing.html
Re: cnc or hand port job 440-1 [Re: racerx] #1375199
01/26/13 09:50 AM
01/26/13 09:50 AM
tboomer Online work
tboomer  Online Work
Here is Dwaynes e-mail addy...
porterheads@gmavt.net
Re: cnc or hand port job 440-1 [Re: n20mstr] #1375200
01/26/13 11:14 AM
01/26/13 11:14 AM
nc
E
E
nc
buyracingparts.com
I think it will come in at 2500lb or under
Re: cnc or hand port job 440-1 [Re: earthmover] #1375201
01/26/13 11:41 AM
01/26/13 11:41 AM
charlotte nc
jimmysarrow Offline
jimmysarrow  Offline
charlotte nc
Call Todd at Marsh Performance - Moparts Connection on the Moparts Home Page. He is located in NC , only does Mopar , and his head guy has a pretty good resume. My 440-1 heads looked almost to good to install on the motor.
Re: cnc or hand port job 440-1 [Re: MR_P_BODY] #1375202
01/26/13 03:50 PM
01/26/13 03:50 PM
I have had Jeff do two sets of 440-1 He put the 2.25 intakes in them at the same time, the first set made 845 HP at 7000 RPM with a Holley 1050 Dominator on a Indy 440-3 intake,440 block stroked to 526 C.I. with mopar rod sizes, not a very trick piece at all The dyno heaaders flanges where to small for the ported heads so the motor missed a little from 5200 RPM up, it would have made a little more power and torque if the headers where better Jeffs CNC programs work good
Re: cnc or hand port job 440-1 [Re: Cab_Burge] #1375203
01/26/13 04:01 PM
01/26/13 04:01 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
porter is doing my heads right now.
Re: cnc or hand port job 440-1 [Re: a493demon] #1375204
01/26/13 07:04 PM
01/26/13 07:04 PM
nc
E
E
nc
they have the 2.25 valves in them now...
Re: cnc or hand port job 440-1 [Re: tboomer] #1375205
01/26/13 09:33 PM
01/26/13 09:33 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thax......i send him an e-mail
Re: cnc or hand port job 440-1 [Re: racerx] #1375206
01/26/13 09:35 PM
01/26/13 09:35 PM
tboomer Online work
tboomer  Online Work
Never bought a thing from him but talked to him on the phone. Dwayne will treat ya right!!
Re: cnc or hand port job 440-1 [Re: tboomer] #1375207
01/27/13 02:08 AM
01/27/13 02:08 AM
Dwayne told me to send my Eddy RPM to Jeff for his CNC program He said that if I wanted the max flow from the heads to send them to Jeff at MCH NO B.S. I've used Jeff ever since then Jeff, I hope your doing well, my prayers are with you
Re: cnc or hand port job 440-1 [Re: Cab_Burge] #1375208
02/18/13 12:17 AM
02/18/13 12:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Do Jeff port the intakes to match the heads?..........
