My Plans have changed to a Hemi #1374990
01/24/13 02:56 PM
01/24/13 02:56 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Building a Aluminum block Hemi with Stage V heads and GRP rods so what size should I go with?
I want atleast 1100 HP.
The KB block is finished at 4.50 now and The rods are 7.100
What would you do.
Re: My Plans have changed to a Hemi [Re: Sammy] #1374991
01/24/13 03:29 PM
01/24/13 03:29 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
at least 600 inches use stage v millennium heads plus a very large pile of cash
home of the
Sox and Martin Hemi Duster
Re: My Plans have changed to a Hemi [Re: HEMIFRED] #1374992
01/24/13 03:33 PM
01/24/13 03:33 PM
dogdays Offline
dogdays  Offline
Build the largest shortblock you can afford.
R.
Re: My Plans have changed to a Hemi [Re: HEMIFRED] #1374993
01/24/13 03:37 PM
01/24/13 03:37 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
I love it when people toss around HP numbers like dirty underwear.
I would to see pictures of the chassis that this engine is going into.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: My Plans have changed to a Hemi [Re: Troy] #1374994
01/24/13 04:40 PM
01/24/13 04:40 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I got the stage V heads already not millienium.
Re: My Plans have changed to a Hemi [Re: Sammy] #1374995
01/24/13 04:48 PM
01/24/13 04:48 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
What stro9ke should I go?
Re: My Plans have changed to a Hemi [Re: Sammy] #1374996
01/24/13 04:51 PM
01/24/13 04:51 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
4.75 stroke if you have a raised cam block with Alum. rods
Re: My Plans have changed to a Hemi [Re: Bishop] #1374997
01/24/13 04:56 PM
01/24/13 04:56 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If you go with a raised cam you will be limited to the expense of a timing belt and if you go with the Millinium head be prepared to modify lifter angle or spacing.When you set your sights to the moon,remember outer space travel gets expensive.Just ask HemiFred.
Re: My Plans have changed to a Hemi [Re: Sammy] #1374998
01/24/13 05:47 PM
01/24/13 05:47 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
raised cam block
Re: My Plans have changed to a Hemi [Re: Sammy] #1374999
01/24/13 07:03 PM
01/24/13 07:03 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
those 600 dollar cams are nice.
Re: My Plans have changed to a Hemi [Re: ro23car] #1375000
01/24/13 07:13 PM
01/24/13 07:13 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
1200 hp costs roughly
block 6,000
rods 1500
pistons pins rings 1500
crank 3,000
intake 3,000
carbs 2,000
belt drive 1400
front drive distributer 500
rocker arms 3500
cam ,push rods, lifters etc 2,000
head complete CNC titanium valves,etc 7500
oil pan oil pump etc 1,000
plus machine work and labor
home of the
Re: My Plans have changed to a Hemi [Re: ro23car] #1375001
01/24/13 07:41 PM
01/24/13 07:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
$600 cams. Man I wish they were that cheap for a 99 Hemi, as well as some of those other pieces and prices Fred listed. For instance the belt drive is $3400 for the 99.
Why not just buy someones 99 Hemi, makes 1300+ HP and only 499"
As stated already build it big and use the best head you can find. Headflow is what will determine HP, well that and RPM. Combine the two and you can make it with a wheel barrow full of cash.
Re: My Plans have changed to a Hemi [Re: HEMIFRED] #1375002
01/24/13 07:51 PM
01/24/13 07:51 PM
Renton Washington
Triple Threat Offline
Renton Washington
block 6,000
rods 1500
crank 3,000
intake 3,000
carbs 2,000
belt drive 1400
rocker arms 3500
This adds up to
$32,900 if anyone was curious. Not including the machine work and labor. So add 4-10K more for that and incidentals
Or, buy Al's 99 and make 1340+ for a fraction.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My Plans have changed to a Hemi [Re: Al_Alguire] #1375003
01/24/13 08:10 PM
01/24/13 08:10 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
A 4.75" crank will fit fine in a standard cam block. I got my rotating assembly from Bob George , I used the chevy width journel crank and the 7.10" steel rods. Very little additional clearancing was required over my old 528 rotating assembly. You'll need some Good heads.Dave
Re: My Plans have changed to a Hemi [Re: quickd100] #1375004
01/24/13 09:31 PM
01/24/13 09:31 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i got 960 out of a 572 with replacement heads and cast crossram. i dont know how much more it would take but i think it could be done without millenium heads.
Re: My Plans have changed to a Hemi [Re: ro23car] #1375005
01/25/13 12:13 AM
01/25/13 12:13 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I got 852hp and 818ftlbs. out of my pumpgas 605. The heads are to small and it's done making power at 5800rpm. It still makes more power than my chassis has been able to use. I'm certain with the right combination you'll hit your goal.Dave
Re: My Plans have changed to a Hemi [Re: quickd100] #1375006
01/25/13 12:19 AM
01/25/13 12:19 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Or, just go the easy way and put a Roots blower on it.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: My Plans have changed to a Hemi [Re: ro23car] #1375007
01/25/13 09:27 AM
01/25/13 09:27 AM
Ohio
hemi-challenger Offline
Ohio
Sam : There is a Keith Black Gear drive for raised cam block on e-bay you might want to look at it.
Re: My Plans have changed to a Hemi [Re: hemi-challenger] #1375008
01/25/13 11:29 AM
01/25/13 11:29 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I got MGP 7.100 aluminum rods and raised cam block.I'm wondering if I could fit a Bryant 4.75 stroke crank with 2.20 journals.I think that's the hot ticket if it works out.
15.5 compression.
Re: My Plans have changed to a Hemi [Re: Sammy] #1375009
01/25/13 01:30 PM
01/25/13 01:30 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Man, after reading all of this & knowing the costs I will have in my HEMI makes me think I should of went with a BBC.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
