Engine travel limiters with an Engine plate?
#1374288
01/22/13 06:06 PM
01/22/13 06:06 PM
Posts: 6,142 Melbourne , Australia
LA360
What are you all using to limit the forward/rearward movement of your engine when running a motor plate? Are you using anything at all? I am helping out a friend with some parts on his car, it's a World RB block and Powerslide trans. He has an engine plate and the standard trans mount. No mid plate unfortunately. The engine bay is painted and there isn't a lot of room in the lower section of the bay. I would love to see some pics of your set ups, or hear your opinions on whether they are required or not? Thanks in advance
Alan Jones
Re: Engine travel limiters with an Engine plate?
[Re: LA360]
#1374290
01/22/13 06:18 PM
01/22/13 06:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yes you need them(at least 1)... if the car launches hard it could bottom out the drive shaft... I use one on both sides of the engine attached to the motor mount ears.... sorry no pics
[Re: LA360]
#1374291
01/22/13 06:36 PM
01/22/13 06:36 PM
Posts: 1,301 Penna
70satelliteguy
Penna
I run a front motor plate on my MP Megablock without any midplate or engine limiters. I run a standard transmission mount and solid motor mounts.I bought a mid plate from S&W but did not have enough room to install with stock firewall,inner fenders and chassis. Have been doing this for the last 6 years without any problems. B body 3600 lbs.,572 motor mid 9's with 1.30 60 fts. Best of 8.62/161 mph with juice! It does leave HARD and has not broken anything yet. Probably 400 + passes! Mike
[Re: 70satelliteguy]
#1374292
01/22/13 06:57 PM
01/22/13 06:57 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
I use the ears on the trans.[727]. They are just infront of the crossmember. I believe they are there to hold the trans during assembly.
A simple strut/rod back to the crossmember will do it.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1374295
01/22/13 09:12 PM
01/22/13 09:12 PM
Posts: 9,836 MI, usa
dvw
MI, usa
Me to. Doug
[Re: Quicktree]
#1374296
01/22/13 09:23 PM
01/22/13 09:23 PM
MR_P_BODY
never used them, but the plate has reinforcement.several cars set up similar with no problems.
Tony.. I dont know why you have those little tubes out there behind the plate at the outside edge... they do nothing
[Re: CHAPPER]
#1374298
01/22/13 10:50 PM
01/22/13 10:50 PM
Posts: 1,169 MI
68shifter
MI
I used 2 off my rear trans crossmember to the bellhousing. 1/2 CM rod with 3/8 ends. Then a rubber mount on the trans. I have a 1/4 front alum plate and a .090 mid plate made of steel. Makes trans removal and clutch work a lot nicer.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: MR_P_BODY]
#1374299
01/23/13 01:29 AM
01/23/13 01:29 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
Mike, looks like to me that those little bars were welded to hold the plate that the motor plate bolts to....rather than just using an "L" off the frame rail.
I didn't use one for years on my RB Mirada... until I was chasing a tail shaft breakage issue, then we installed one. That wasn't the problem.
[Re: J_BODY]
#1374300
01/23/13 01:42 AM
01/23/13 01:42 AM
MR_P_BODY
I swear I see a bracket "L" welded to the frame and he is holding the top of the plate with those bars
[Re: MR_P_BODY]
#1374301
01/24/13 06:41 PM
01/24/13 06:41 PM
LA360
Thanks for the replies
Will have to get under the car today and have a look and see where we can put something.
Alan Jones
[Re: LA360]
#1374302
01/24/13 07:06 PM
01/24/13 07:06 PM
MR_P_BODY
Look at maybe going to the oil pan bolts at the front corners and going forward... if you use those I would use 2 limiters... if you have zero momentum its easier to hold it still
[Re: MR_P_BODY]
#1374303
01/24/13 07:12 PM
01/24/13 07:12 PM
Quicktree
been 300+ passes no problems,
[Re: Quicktree]
#1374304
01/24/13 07:17 PM
01/24/13 07:17 PM
Posts: 401 dayton,ohio
ROSSIO
dayton,ohio
after breaking 3 tailstock housings--i got smart and fixed the problem----FLEX---- I did what DVW did to fix mine,i made bars from the trans mount to the ears on the trans---FIX IT--never broke another ext housing
1970 DART B1MC N/A
8.86@ [Email]155
3200 lb on 275 DR
5.30 @ 130 1/8
[Re: CHAPPER]
#1374309
01/24/13 11:14 PM
01/24/13 11:14 PM
Posts: 1,443 Maryland
Dads426
Maryland
when I got the car in the sig pic the trans mount was destroyed, so I looked into an engine limiter. The engine compartment is tight and I wanted to limit the fore and aft movement as direct as possible and not have a single limiter angled in any way, so I built a bracket that mounts to 4 pan studs with a straight shot to two tabs welded on the K-frame. It was a S&W kit (I believe). It was been on there for 4 years and still works great. I thought the pan studs would be stressed, but they are all still straight and I think spreading the load over 4 studs helped. The motor is out of the car if you want pics of the bracket.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: LA360]
#1374310
01/24/13 11:47 PM
01/24/13 11:47 PM
Posts: 793 Utah
topbrent
Utah
[Re: JoWeTu_6]
#1374314
01/25/13 05:32 PM
01/25/13 05:32 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
I personally wouldn't use the trans ear to crossmember version as I think it would still put a lot of strain on the aluminum transmission case, it may work for some, but I'd rather go from the motor mount pads to the k member or frame rails.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#1374315
01/25/13 06:08 PM
01/25/13 06:08 PM
MR_P_BODY
I dont see a problem using them... its on the main case and is applying the load forward through the case.. if it were on the tailshaft I would look elsewhere... I use the engine mount ears also but if you think about it, the limiters could stress the block in that area .... JMO
[Re: topfueldart]
#1374316
01/25/13 09:37 PM
01/25/13 09:37 PM
dvw
MI, usa
I have the same question and I did it anyway. I'll let you know how it works out. Doug
[Re: dvw]
#1374317
01/26/13 08:52 PM
01/26/13 08:52 PM
LA360
We are probably going to go off the trans ears on his Glide. If the World block was machined for the Hemi? (Three threaded holes in the block, rather than the ears/lugs), we would have gone off there.
Thanks for the pics and replies
Alan Jones
