Re: Engine travel limiters with an Engine plate? [Re: hemi-itis] #1374308
01/24/13 08:40 PM
01/24/13 08:40 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I like the looks of using the trans ears, but appears it would really cramp my shifter cable mount area and the trans blanket..
If you like drag racing, support your local track.
Re: Engine travel limiters with an Engine plate? [Re: CHAPPER] #1374309
01/24/13 11:14 PM
01/24/13 11:14 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
when I got the car in the sig pic the trans mount was destroyed, so I looked into an engine limiter. The engine compartment is tight and I wanted to limit the fore and aft movement as direct as possible and not have a single limiter angled in any way, so I built a bracket that mounts to 4 pan studs with a straight shot to two tabs welded on the K-frame. It was a S&W kit (I believe). It was been on there for 4 years and still works great. I thought the pan studs would be stressed, but they are all still straight and I think spreading the load over 4 studs helped. The motor is out of the car if you want pics of the bracket.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Engine travel limiters with an Engine plate? [Re: LA360] #1374310
01/24/13 11:47 PM
01/24/13 11:47 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Re: Engine travel limiters with an Engine plate? [Re: LA360] #1374311
01/25/13 04:03 PM
01/25/13 04:03 PM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
This is what I did it seems to ok for me, just another idea for you to take a look at.
Hope it helps ya.
First pic:
Re: Engine travel limiters with an Engine plate? [Re: JoWeTu_6] #1374312
01/25/13 04:05 PM
01/25/13 04:05 PM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Second pic
Re: Engine travel limiters with an Engine plate? [Re: JoWeTu_6] #1374313
01/25/13 04:07 PM
01/25/13 04:07 PM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Third pic
Re: Engine travel limiters with an Engine plate? [Re: JoWeTu_6] #1374314
01/25/13 05:32 PM
01/25/13 05:32 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
I personally wouldn't use the trans ear to crossmember version as I think it would still put a lot of strain on the aluminum transmission case, it may work for some, but I'd rather go from the motor mount pads to the k member or frame rails.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Engine travel limiters with an Engine plate? [Re: topfueldart] #1374315
01/25/13 06:08 PM
01/25/13 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont see a problem using them... its on the main
case and is applying the load forward through the
case.. if it were on the tailshaft I would look elsewhere...
I use the engine mount ears also but if you think
about it, the limiters could stress the block in that
area .... JMO
Re: Engine travel limiters with an Engine plate? [Re: topfueldart] #1374316
01/25/13 09:37 PM
01/25/13 09:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have the same question and I did it anyway. I'll let you know how it works out.
Doug
Re: Engine travel limiters with an Engine plate? [Re: dvw] #1374317
01/26/13 08:52 PM
01/26/13 08:52 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
We are probably going to go off the trans ears on his Glide. If the World block was machined for the Hemi? (Three threaded holes in the block, rather than the ears/lugs), we would have gone off there.
Thanks for the pics and replies
Alan Jones
