Engine travel limiters with an Engine plate? #1374288
01/22/13 06:06 PM
01/22/13 06:06 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
What are you all using to limit the forward/rearward movement of your engine when running a motor plate? Are you using anything at all?
I am helping out a friend with some parts on his car, it's a World RB block and Powerslide trans. He has an engine plate and the standard trans mount. No mid plate unfortunately. The engine bay is painted and there isn't a lot of room in the lower section of the bay.
I would love to see some pics of your set ups, or hear your opinions on whether they are required or not?
Thanks in advance
Alan Jones
Re: Engine travel limiters with an Engine plate? [Re: LA360] #1374289
01/22/13 06:13 PM
01/22/13 06:13 PM
Out West
408strokerdart Offline
Out West
Yes. They are required. The plate only gives the required strength in the torsional shear plane. You need something ridgid for fore/aft in the car. Usually done with a couple of rod ends in a tube and a couple of brackets. The original engine mounts are a great place to attach to the engine. Opinions will vary here for sure.
Re: Engine travel limiters with an Engine plate? [Re: LA360] #1374290
01/22/13 06:18 PM
01/22/13 06:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you need them(at least 1)... if the car launches
hard it could bottom out the drive shaft... I use
one on both sides of the engine attached to the motor
mount ears.... sorry no pics
Re: Engine travel limiters with an Engine plate? [Re: LA360] #1374291
01/22/13 06:36 PM
01/22/13 06:36 PM
Penna
70satelliteguy Offline
Penna
I run a front motor plate on my MP Megablock without any midplate or engine limiters. I run a standard transmission mount and solid motor mounts.I bought a mid plate from S&W but did not have enough room to install with stock firewall,inner fenders and chassis. Have been doing this for the last 6 years without any problems.
B body 3600 lbs.,572 motor mid 9's with 1.30 60 fts. Best of 8.62/161 mph with juice! It does leave HARD and has not broken anything yet. Probably 400 + passes!
Mike
Re: Engine travel limiters with an Engine plate? [Re: 70satelliteguy] #1374292
01/22/13 06:57 PM
01/22/13 06:57 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I use the ears on the trans.[727]. They are just infront of the crossmember. I believe they are there to hold the trans during assembly.
A simple strut/rod back to the crossmember will do it.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Engine travel limiters with an Engine plate? [Re: 6bblFLASH] #1374293
01/22/13 07:04 PM
01/22/13 07:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
never used them, but the plate has reinforcement.several cars set up similar with no problems.
Re: Engine travel limiters with an Engine plate? [Re: LA360] #1374294
01/22/13 08:14 PM
01/22/13 08:14 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
S & w sells a universal kit like 408 described. Its not expensive and all the parts are there.
Re: Engine travel limiters with an Engine plate? [Re: 6bblFLASH] #1374295
01/22/13 09:12 PM
01/22/13 09:12 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Me to.
Doug
Re: Engine travel limiters with an Engine plate? [Re: Quicktree] #1374296
01/22/13 09:23 PM
01/22/13 09:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tony.. I dont know why you have those little tubes
out there behind the plate at the outside edge...
they do nothing
Re: Engine travel limiters with an Engine plate? [Re: MR_P_BODY] #1374297
01/22/13 10:33 PM
01/22/13 10:33 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
they do nothing
Those should hold a small block just fine.
If you like drag racing, support your local track.
Re: Engine travel limiters with an Engine plate? [Re: CHAPPER] #1374298
01/22/13 10:50 PM
01/22/13 10:50 PM
MI
68shifter Offline
68shifter  Offline
MI
I used 2 off my rear trans crossmember to the bellhousing. 1/2 CM rod with 3/8 ends. Then a rubber mount on the trans. I have a 1/4 front alum plate and a .090 mid plate made of steel. Makes trans removal and clutch work a lot nicer.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Engine travel limiters with an Engine plate? [Re: MR_P_BODY] #1374299
01/23/13 01:29 AM
01/23/13 01:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Mike, looks like to me that those little bars were welded to hold the plate that the motor plate bolts to....rather than just using an "L" off the frame rail.
I didn't use one for years on my RB Mirada... until I was chasing a tail shaft breakage issue, then we installed one. That wasn't the problem.
Re: Engine travel limiters with an Engine plate? [Re: J_BODY] #1374300
01/23/13 01:42 AM
01/23/13 01:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I swear I see a bracket "L" welded to the frame and
he is holding the top of the plate with those bars
Re: Engine travel limiters with an Engine plate? [Re: MR_P_BODY] #1374301
01/24/13 06:41 PM
01/24/13 06:41 PM
LA360 Offline OP
LA360  Offline OP
Thanks for the replies
Will have to get under the car today and have a look and see where we can put something.
Alan Jones
Re: Engine travel limiters with an Engine plate? [Re: LA360] #1374302
01/24/13 07:06 PM
01/24/13 07:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look at maybe going to the oil pan bolts at the front
corners and going forward... if you use those I would
use 2 limiters... if you have zero momentum its easier
to hold it still
Re: Engine travel limiters with an Engine plate? [Re: MR_P_BODY] #1374303
01/24/13 07:12 PM
01/24/13 07:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
they do nothing
been 300+ passes no problems,
Re: Engine travel limiters with an Engine plate? [Re: Quicktree] #1374304
01/24/13 07:17 PM
01/24/13 07:17 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
after breaking 3 tailstock housings--i got smart and fixed the
problem----FLEX----
I did what DVW did to fix mine,i made bars from the trans mount to the ears on the trans---FIX IT--never broke another ext housing
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: Engine travel limiters with an Engine plate? [Re: MR_P_BODY] #1374305
01/24/13 07:27 PM
01/24/13 07:27 PM
LA360 Offline OP
LA360  Offline OP
to hold it still
We looked at the pan bolts, I might see if I can go from the transmission case first.
Thanks again everyone
Alan Jones
Re: Engine travel limiters with an Engine plate? [Re: ROSSIO] #1374306
01/24/13 07:28 PM
01/24/13 07:28 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
Pics?
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Engine travel limiters with an Engine plate? [Re: fed] #1374307
01/24/13 08:28 PM
01/24/13 08:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Thought I've read that it's NOT good to go to the trans ears
I need to do something,but don't see a good spot
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
