TTI SB Headers Fitment Issues A-Body 67 to 76 Step Hdr #1374091
01/22/13 01:28 AM
01/22/13 01:28 AM
San Diego
formula S Offline OP
San Diego
These headers do not fit properly on 67 to 72 year model cars, they do fit on 73 and up due to the difference in the steering linkage on 67 to 72 cars the tierod end studs face up and hit the headers every time and TTI provides instructions on how to get them to fit which requires shimming the engine up 3/8" to 1/2" which raises the engine 1/2" to 5/8" higher measured at the crank so now with the engine in its new location which is out of factory spec by the way, we now have new issues crop up with distributor and hood clearence I have spoke to TTI about fixing the problem and there is room to do so and they said to shim the engine up and move the engine back to get proper clearence well all of this jockying around is just the "tail waggin the dog" I am pretty sure they used 73 or newer car for their template, they should adjust the headers so we dont have to reengineer our cars to fit their headers
Please post if you've had similar problems with these headers. Thanks
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374092
01/22/13 01:34 AM
01/22/13 01:34 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Had a set on my 71 Dart 318 for many years....and it has the correct drag link for a 71...
Tony
70 AARCuda Vitamin C
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374093
01/22/13 02:12 AM
01/22/13 02:12 AM
Renton Washington
Triple Threat Offline
Renton Washington
Ok, what size header are you referring to? I'm assuming small block?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: Triple Threat] #1374094
01/22/13 02:19 AM
01/22/13 02:19 AM
San Diego
San Diego
340-360 1 5/8" to 1 3/4" step
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374095
01/22/13 03:53 AM
01/22/13 03:53 AM
Renton Washington
Renton Washington
I had that header on my dart, on a 340 and a 318. 67 /6 K frame and shumacher conversion mounts, it cleared no issues.
We had the same set of headers on a 67 dart, 73+ K frame It cleared everything as well.
You either got a bad set, or something is off here.
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374096
01/22/13 11:00 AM
01/22/13 11:00 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The tie rod ends hit mine too. I now have Hedman Huslers , 69 Dart.
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: justinp61] #1374097
01/22/13 11:21 AM
01/22/13 11:21 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i have a fabricated trans mount..it makes the rear of the trans sit higher...not sure if that effects things..but mine clear...on my 72..but i may have the 73 center link..not sure...because i do have the 73 disc brakes..i might have gotten the center link when i got the brakes from the junk yard. cant remember..
why cant you just buy a 73 center link..?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: Triple Threat] #1374098
01/22/13 11:43 AM
01/22/13 11:43 AM
San Diego
San Diego
I've done six installs on these headers, four on original 67 to 72 V-8 cars they all required shimming 3/8" to 1/2". Shumacher conversion mounts and K-member swaps to 73 K-members isnt what im refuring to, its the original 67 to 76 V-8 cars. Two of the cars I've done are 73's no clearence issues on these cars, the reason is the idler arm and tierod studs faces the opposite direction from the early cars and are completely out of the way
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: cheapstreetdustr] #1374099
01/22/13 11:48 AM
01/22/13 11:48 AM
San Diego
San Diego
It uses different idler and pitman arms
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374100
01/22/13 12:20 PM
01/22/13 12:20 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
I have them on my 72 demon with no issues as well, original 340 k-member and solid mounts. I didn't shim anything.
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: moparfan] #1374101
01/22/13 12:36 PM
01/22/13 12:36 PM
San Diego
San Diego
Solid mounts dont compress
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374102
01/22/13 01:44 PM
01/22/13 01:44 PM
Central New York
bfury Offline
bfury  Offline
Central New York
I have an original 72 340 Duster with these headers, about 10 ir 12 years old. I never shimmed and the tie rods do graze the headers. I havwn't done anything to correct although we did shim the trans mount to align the u joints 5 years ago. I have always driven it this way with no problems.
No Stock
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: bfury] #1374103
01/22/13 08:14 PM
01/22/13 08:14 PM
San Diego
San Diego
There's got to be a few more out there that use these headers, what's been your experience. Thanks again
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374104
01/23/13 09:11 AM
01/23/13 09:11 AM
San Diego
San Diego
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: formula S] #1374105
01/23/13 11:29 AM
01/23/13 11:29 AM
Well, they fit my 67 just fine with no shimming. Original slant 6 car with a 68-9 V-8 K-frame and idler arm. Maybe I was just lucky?
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header #1374106
01/23/13 04:06 PM
01/23/13 04:06 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Me and my dad installed them on my moms 67 barracuda. No shimming or fitment issues..
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: 69B3GT] #1374107
01/23/13 04:22 PM
01/23/13 04:22 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
They fit mine but had to shim , alittle mod to the z bar four speed car,and went to a smaller starter.
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: fasthawk6] #1374108
01/23/13 10:03 PM
01/23/13 10:03 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
My 69 Dart with a 340 I had to shim up the motor about 3/8" as well as notch one tube on the right side to clear the tie rod nut or maybe it was the idler arm nut-either way. Heated it and rounded it with a socket. No other issues with clearance like the dist. I also picked up a spare set from a guy that took them off his 72 Dart and he tweaked those a little as well.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: G-Money1320] #1374109
01/24/13 01:33 AM
01/24/13 01:33 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I have two 1/8" shims on pass side and one shim on drivers side. I enlarged the rear k-frame slot on drivers side to get the engine to slide back. Sliding back that engine gave me tons of steering linkage clearance. No dents and headers fit great. I had to mess with them for a couple days to get them to fit. The factory k-frames are really sloppy so every car is different.
Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header [Re: 69Cuda340S] #1374110
01/24/13 10:43 PM
01/24/13 10:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They fit my 68 cuda great and a set I put on a 67 fit great, both were originally SB cars.
