Re: TTI Headers Fitment Issues A-Body 67 to 76 Step Header
[Re: formula S]
#1374092
01/22/13 01:34 AM
01/22/13 01:34 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Had a set on my 71 Dart 318 for many years....and it has the correct drag link for a 71...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: formula S]
#1374093
01/22/13 02:12 AM
01/22/13 02:12 AM
Triple Threat
Renton Washington
Ok, what size header are you referring to? I'm assuming small block?
[Re: Triple Threat]
#1374094
01/22/13 02:19 AM
01/22/13 02:19 AM
Posts: 660 San Diego
formula S
San Diego
340-360 1 5/8" to 1 3/4" step
[Re: formula S]
#1374096
01/22/13 11:00 AM
01/22/13 11:00 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
The tie rod ends hit mine too. I now have Hedman Huslers , 69 Dart.
[Re: justinp61]
#1374097
01/22/13 11:21 AM
01/22/13 11:21 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i have a fabricated trans mount..it makes the rear of the trans sit higher...not sure if that effects things..but mine clear...on my 72..but i may have the 73 center link..not sure...because i do have the 73 disc brakes..i might have gotten the center link when i got the brakes from the junk yard. cant remember.. why cant you just buy a 73 center link..?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Triple Threat]
#1374098
01/22/13 11:43 AM
01/22/13 11:43 AM
formula S
San Diego
I had that header on my dart, on a 340 and a 318. 67 /6 K frame and shumacher conversion mounts, it cleared no issues.
We had the same set of headers on a 67 dart, 73+ K frame It cleared everything as well.
You either got a bad set, or something is off here.
I've done six installs on these headers, four on original 67 to 72 V-8 cars they all required shimming 3/8" to 1/2". Shumacher conversion mounts and K-member swaps to 73 K-members isnt what im refuring to, its the original 67 to 76 V-8 cars. Two of the cars I've done are 73's no clearence issues on these cars, the reason is the idler arm and tierod studs faces the opposite direction from the early cars and are completely out of the way
[Re: cheapstreetdustr]
#1374099
01/22/13 11:48 AM
01/22/13 11:48 AM
formula S
San Diego
It uses different idler and pitman arms
[Re: formula S]
#1374100
01/22/13 12:20 PM
01/22/13 12:20 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
I have them on my 72 demon with no issues as well, original 340 k-member and solid mounts. I didn't shim anything.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
[Re: moparfan]
#1374101
01/22/13 12:36 PM
01/22/13 12:36 PM
formula S
San Diego
Solid mounts dont compress
[Re: formula S]
#1374102
01/22/13 01:44 PM
01/22/13 01:44 PM
Posts: 404 Central New York
bfury
Central New York
I have an original 72 340 Duster with these headers, about 10 ir 12 years old. I never shimmed and the tie rods do graze the headers. I havwn't done anything to correct although we did shim the trans mount to align the u joints 5 years ago. I have always driven it this way with no problems.
No Stock
[Re: formula S]
#1374105
01/23/13 11:29 AM
01/23/13 11:29 AM
Well, they fit my 67 just fine with no shimming. Original slant 6 car with a 68-9 V-8 K-frame and idler arm. Maybe I was just lucky?
[Re: fasthawk6]
#1374108
01/23/13 10:03 PM
01/23/13 10:03 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
My 69 Dart with a 340 I had to shim up the motor about 3/8" as well as notch one tube on the right side to clear the tie rod nut or maybe it was the idler arm nut-either way. Heated it and rounded it with a socket. No other issues with clearance like the dist. I also picked up a spare set from a guy that took them off his 72 Dart and he tweaked those a little as well.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: 69Cuda340S]
#1374110
01/24/13 10:43 PM
01/24/13 10:43 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
They fit my 68 cuda great and a set I put on a 67 fit great, both were originally SB cars.
