Which direction do the slots go? #1374028
01/21/13 11:18 PM
01/21/13 11:18 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
I am putting drilled and slotted rotors on my Dakota, and ordered a set of slotted rotors but they are not marked left/right (driver/passenger).
I have heard two different people say two different directions.
A dirt racer friend of mine says they mount the slot // with the point toward the front, another guy said \\ slot points toward the rear...
Does it even matter which direction they go?
single choice
Votes accepted starting: 01/21/13 10:18 PM
Re: Which direction do the slots go? [Re: hp383] #1374029
01/21/13 11:21 PM
01/21/13 11:21 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
if they have cooling fins in the middle you want them to scoop the air...the slots usually go forward as they match the cooling fins. did they have a side denoted on the box?
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Which direction do the slots go? [Re: pnypwr] #1374030
01/21/13 11:27 PM
01/21/13 11:27 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
No, no label of any sort.
The rotor does have internal cooling fins that the holes are drilled into, the slots do not go deep enough to reach the fins.
Re: Which direction do the slots go? [Re: hp383] #1374031
01/21/13 11:42 PM
01/21/13 11:42 PM
Johnstown ohio
BluCuda Offline
BluCuda  Offline
Johnstown ohio
They should be mounted so that the air is forced thru the slot from the center of the hub to the outside of the disc when rotating in a foreward direction.
Re: Which direction do the slots go? [Re: BluCuda] #1374032
01/21/13 11:49 PM
01/21/13 11:49 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
So this would go on the passenger side correct?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Which direction do the slots go? [Re: BluCuda] #1374033
01/22/13 12:32 AM
01/22/13 12:32 AM
Johnstown ohio
BluCuda Offline
BluCuda  Offline
Johnstown ohio
I wasn,t very clear. You want the internal cooling vanes picking the air up from the center of the hub and forcing the air outward.
Re: Which direction do the slots go? [Re: BluCuda] #1374034
01/22/13 12:38 AM
01/22/13 12:38 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
So my pictured hub would be drivers side then
Re: Which direction do the slots go? [Re: hp383] #1374035
01/22/13 12:51 AM
01/22/13 12:51 AM
Johnstown ohio
BluCuda Offline
BluCuda  Offline
Johnstown ohio
The internal vanes determine rotor direction not the outside machined grooves. If the grooves on the outside are facing the same direction as the internal vanes, then that is your left or driver side rotor.
Re: Which direction do the slots go? [Re: BluCuda] #1374036
01/22/13 12:54 AM
01/22/13 12:54 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
ignore the holes and slots that are machined into the rotor. the vanes inside can be in the same direction, they may not be. they may be straight vanes.
if the vanes in the middle are straight, then the rotors can go on either side.
http://zeckhausen.com/how_to_properly_install_rotors.htm
**Photobucket sucks**
Re: Which direction do the slots go? [Re: 70Cuda383] #1374037
01/22/13 01:36 AM
01/22/13 01:36 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
OK, now I got it!
Thanks you guys.
Re: Which direction do the slots go? [Re: 70Cuda383] #1374038
01/22/13 04:06 PM
01/22/13 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My SRT Challenger has Brembo brakes with angled slots and the slots point rearward on the left and forward on the right i.e. rotors are interchangeable right/left.
