best intake for sbm with w-2 heads #1373534
01/21/13 01:48 PM
01/21/13 01:48 PM
selah, washington
72340dustermike Offline OP
selah, washington
im putting together a 0.40 over 340 with wisco 12/1 forged pistons
.590 lift cam roller rocker, roller lifters, oh ya stock stroke
i plan to lauch the car at 4200 shift at 7800
it is strictly a race motor in a 3200lb duster
would appreciate any help, looking for best flowing intake to
work with this combo as the heads have had work done to them also
thanks
Re: best intake for sbm with w-2 heads [Re: 72340dustermike] #1373535
01/21/13 03:48 PM
01/21/13 03:48 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I run a Victor W2 but mine is a 416. I shift a 7000. I have run an Indy but the Victor was better by .03 and 3 mph.
Re: best intake for sbm with w-2 heads [Re: 72340dustermike] #1373536
01/21/13 04:11 PM
01/21/13 04:11 PM
SoCal
Brian Hafliger Offline
SoCal
The cheapest best intake is the Victor with a 1" open spacer.
The Indy with 1" cut off and a 1" tapered spacer will make more avg. power but at a premium cost compared to the victor. However, the Indy needs minor port work at the flange, so if you compare a full port on the Victor vs. Indy they might be close in price...only other factor would be carb height on Indy is fairly tall.
Brian
Brian Hafliger
Re: best intake for sbm with w-2 heads [Re: 72340dustermike] #1373537
01/21/13 04:26 PM
01/21/13 04:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like my Indy... I use the 1050 adapter to run
a 1050... runs great to 8200 on my 396ci... I used
it on my 340+ .030 and it pulled hard to 8000 but
that was about the limit on the cam
Re: best intake for sbm with w-2 heads [Re: 72340dustermike] #1373538
01/21/13 09:22 PM
01/21/13 09:22 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
As Brian said- the Victor is a good intake for a reasonable price- pretty hard to go wrong with. I ran one for a while and it was a good piece- I would buy it again if I went back to W2's.
Re: best intake for sbm with w-2 heads [Re: 72demon416] #1373539
01/21/13 09:45 PM
01/21/13 09:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have a Holley Strip Dominator on mine (368") but I suppose a newer intake might make a bit more power.
Re: best intake for sbm with w-2 heads [Re: topside] #1373540
01/21/13 10:44 PM
01/21/13 10:44 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
How much better than the M-1 is the Victor?
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: best intake for sbm with w-2 heads [Re: moparfan] #1373541
01/22/13 12:30 AM
01/22/13 12:30 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I had both on back to back and while I never got any numbers down with the M1 the victor pulled noticeably harder in the upper rpms.
Re: best intake for sbm with w-2 heads [Re: moparfan] #1373542
01/22/13 12:31 AM
01/22/13 12:31 AM
SoCal
SoCal
Depends on the build...
Brian Hafliger
Re: best intake for sbm with w-2 heads [Re: Brian Hafliger] #1373543
01/22/13 11:25 AM
01/22/13 11:25 AM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
How is the Holley Pro-dominator tunnelram?
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: best intake for sbm with w-2 heads [Re: Brian Hafliger] #1373544
01/22/13 12:26 PM
01/22/13 12:26 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
Hi Brian, similar build to the orginal poster,11 to 1, hensley stage 2 ported w-2 econo long valve,72 cc open chamber head, the M-1 intake appears to be just gasket matched. the water port from the t-stat housing is blocked as well. 5500 8" converter 4:30 gear. The car has lazy 60' now (1.60 best)3250 lbs.
Mine is 40 over as well, 3.79 stroke. Crane .580" .600" lift, 268, 278 duration @ .050 crane flat tappet cam, Installed at card spec
Re: best intake for sbm with w-2 heads [Re: moparfan] #1373545
01/22/13 12:42 PM
01/22/13 12:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2 things I would look at... first what RPM are you
leaving at and have you played with the squirters
and pump cams
Re: best intake for sbm with w-2 heads [Re: moparfan] #1373546
01/22/13 01:54 PM
01/22/13 01:54 PM
SoCal
SoCal
Way too much cam for that combo! I would run something closer to 260@ .050 on a 107 and advance it alot.
Most of my 60ft. I found with CHASSIS and not engine, but that cam is wrong for what your doing.
Brian
Brian Hafliger
Re: best intake for sbm with w-2 heads [Re: fed] #1373547
01/22/13 10:05 PM
01/22/13 10:05 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i have ran the victor,indy and pro dominator tunnelram and the indy was the fastest on my 398 w2 motor
Re: best intake for sbm with w-2 heads [Re: Plymouth340] #1373548
01/22/13 10:32 PM
01/22/13 10:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran the pro dom TR on mine also and the M1 TR..the
M1 was quicker and faster BUT thats apples to oranges
to the single 4bbl intakes
Re: best intake for sbm with w-2 heads [Re: MR_P_BODY] #1373549
01/23/13 11:56 PM
01/23/13 11:56 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Does anyone want to take a stab @ where the M1 falls as far as cid and rpm and explain the differences between the M1, victor and Indy and the best applications for each
Re: best intake for sbm with w-2 heads [Re: emarine01] #1373550
01/24/13 12:08 AM
01/24/13 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think Brian or someone with a dyno would be best
suited for that... it would eliminate some variables
Re: best intake for sbm with w-2 heads [Re: MR_P_BODY] #1373551
01/26/13 08:43 PM
01/26/13 08:43 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Humm... No takers on this one,
