Page 6 of 7 1 2 3 4 5 6 7
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373446
02/28/13 06:59 PM
02/28/13 06:59 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Any inter cooler? I assume this is an external waste gate turbo correct?
Is it coolant fed or just oiled? What kind of mods for oil return? Boost controller?
Re: budget turbo Belvedere still alive and well [Re: GTX MATT] #1373447
02/28/13 07:06 PM
02/28/13 07:06 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
The pic should answer your wastegate and intercooler question
It's journal bearing, oil only
Only oil return mod was using a Sharp chisel to punch a hole in the pan.
I used a npt nipple fitting and some super silicone they use to glue Phord diesels together.
That's it !!!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373448
02/28/13 07:14 PM
02/28/13 07:14 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Here is another of it on the pump
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373449
02/28/13 07:22 PM
02/28/13 07:22 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Gotcha just getting ahead of myself!
Link to you video is below, sounds tough!
http://www.youtube.com/watch?v=6Ux_0zeEG9I
That thing is extremely impressive, especially considering NO INTERCOOLER!
Re: budget turbo Belvedere still alive and well [Re: GTX MATT] #1373450
02/28/13 07:30 PM
02/28/13 07:30 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Thanks for posting the link !!!!!!
Hands down its the most fun car I own !!!!! Second is my 11 second 318 Poly
And that's NOT using the sneeze !!!!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373451
02/28/13 07:34 PM
02/28/13 07:34 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Here is a pic of the Poly
Haven't used the sneeze yet !!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373452
02/28/13 07:42 PM
02/28/13 07:42 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
A pic of after dyno, waiting to go back into service !!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373453
02/28/13 07:45 PM
02/28/13 07:45 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I think the turbo inlet is black from exhaust from the wastegate, I don't have any pipe on it.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373454
03/03/13 12:22 PM
03/03/13 12:22 PM
Jarrettsville, MD
cudaman1967 Offline
cudaman1967  Offline
Jarrettsville, MD
I have a s480 with race cover. Put motor in cuda back in 2009. Just pulled out over winter to freshen up. I have a CSU 1050 dominator on it. 446 cube with a 580 flat tappet turbo cam.
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: budget turbo Belvedere still alive and well [Re: cudaman1967] #1373455
03/03/13 12:24 PM
03/03/13 12:24 PM
Jarrettsville, MD
cudaman1967 Offline
cudaman1967  Offline
Jarrettsville, MD
I have been 8.84 154mph. I drive it everywhere. Very realiable and driveable. 15 lbs boost, water meth kit, pump gas.
Re: budget turbo Belvedere still alive and well [Re: cudaman1967] #1373456
03/04/13 02:03 AM
03/04/13 02:03 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
That's pritty sweet !!!!!
I was thinking about getting race covers for my S475 if they make them.
Once weather gets better I'm gonna drag it out and see if I can get the S475 to fit.
Then its fuel system time !!!!
Re: budget turbo Belvedere still alive and well [Re: cudaman1967] #1373457
03/04/13 01:42 PM
03/04/13 01:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
care to share any more info on the set-up? I'd like to go boosted for the next build. Nothing like high eights but I'd like to be able to drive to M/D (50 miles) or MIR (65miles) run low 10's and drive home.
Coming soon!!!!
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373458
03/04/13 03:11 PM
03/04/13 03:11 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I wouldn't mind some of your build specs either.
I have a Bee that is still in the progress of getting twins
But I might set it up for some street duty.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373459
03/04/13 05:31 PM
03/04/13 05:31 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I love what you're doing here... as with a ton of people, I eventually want to run a homebuilt turbo on my Super Bee and have been off and on planning things for a while. Im sure the ratio of people that plan a turbo build to people that actually do a turbo build is 100:1 so good job on getting it done!
Anyway, how big is your downpipe, and did you have any trouble routing it down the firewall and under the car? Also, is it hooked up to an exhaust system? Are you planning on routing the wastegate out of the engine pay, or just continue dumping it?
Thanks!
Paul
'69 Super Bee 383 EFI Turbo
Re: budget turbo Belvedere still alive and well [Re: Black_Bee] #1373460
03/04/13 11:35 PM
03/04/13 11:35 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
If memory serves me rite the pipe is 3.5
It's a bit tite with the column shift linkage but it fits.
It dumps just below the drivers seat or should I say bench LOL
No muffler needed, its very quiet until you get after it then its just turbo whistle
I don't plan on a pipe on the wastegate yet
If the car was really nice then I prolly would
I like racing it cause it looks scabby, its always fun pounding a fox body or camaro up there assess after they just wiped on a fresh coat of race glaze LOL
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373461
04/21/13 11:06 PM
04/21/13 11:06 PM
Ohio
Cincylance Offline
Cincylance  Offline
Ohio
Wow, so what would a turbo add to a 625hp 472ci Hemi w/10.5:1?
Very interesting!
Cincylance
Re: budget turbo Belvedere still alive and well [Re: cudaman1967] #1373462
04/22/13 02:11 AM
04/22/13 02:11 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
That thing looks awesome! I havent seen it since you got it painted! Your car is what pushed me to turbos from nitrous! Id like to know more about your tuning set up. Timing? how are you running the water meth? Mixture? I have mine about done again after cooking the last set of pistons..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373463
12/31/13 06:44 AM
12/31/13 06:44 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Budget Turbo Belvedere is still alive and kicking !!!!!
Switched to M1 but haven't got a chance to run it yet.
Who on here put a little boost to there Mopar?!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373464
12/31/13 11:14 AM
12/31/13 11:14 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
My little 318 is still chugging along after 2 hard years. Number 8 piston still has a nice crack in in but I haven't eaten any head gaskets lately I am at the limit of head/cam now makes abunch of power then feels like it hits a wall with the boost still climbing. I'm waiting to kill this motor before I swap my 360 in but it just won't die!! It does have a N20 kit now so when the track opens I'll either finish it off or my 60' will pick up It's alot of fun on the street but most of the local people have figured it out so stoplight challenges don't happen much anymore
Re: budget turbo Belvedere still alive and well [Re: SLOW67] #1373465
01/02/14 06:22 PM
01/02/14 06:22 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Please keep this post going guys, I want to learn as much as I can. Turbo size is what's the most confusing right now for me. I have a nice 360 Magnum with the m1 intake that I think this would be perfect for. I leaning the EFI way right now since it seems cheeper if starting from scratch. These cars are supper!
