Page 5 of 7 1 2 3 4 5 6 7
Re: budget turbo Belvedere still alive and well [Re: Quicksilver440] #1373426
01/27/13 01:11 PM
01/27/13 01:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
carb isn't an issue. MSD had a boost delay/retard box you can add on. It lets you drop from .5* to 4* per lb of boost. The carb and the delay box are a much easier instal than a EFI set-up and WAY cheaper.
easier yes...but if you buy a setup forced induction carb, not that much cheaper than my setup once you figure in the ignition and tunability that comes built in the LS1 ignition/Efi.
I paid about $200 for my carb to be boost preped, $50 for my MSD delay box...
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373427
01/27/13 01:24 PM
01/27/13 01:24 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Which MSD box?
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373428
01/27/13 01:33 PM
01/27/13 01:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Which MSD box?
boost delay/retard box, mounts under the dash so you can drop timing out. Got it used off of e-bay. I already had MSD on the car.
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373429
01/27/13 01:52 PM
01/27/13 01:52 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I think the efi is nice but for the majority of people that want to build something like what I have I'm shure most will run a carb.
It's easy and way cheaper, to mod a 750-800 dp Holley
Only takes time, and Msd, Mallory ignition can be found cheap
For a hyfire 6 al with the big coil and a dual point dizzy I paid 35 bucks and I don't need a labtop or any other computer savy stuff to tune it in
Dizzy locked out @ 28 that's it no boost retard
Surf eBay and Craigslist for carbs and parts
For some one that wants to make numbers like what I have I would suggest checking the guys that run dirt roundy round stuff.
And start with a Alky carb, make shure it has power valve circuit
For someone that don't want to turn the wick up that far a normal dp Holley works fine
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373430
01/27/13 03:15 PM
01/27/13 03:15 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I hear you...but you are not counting the cost of the carb you are modifing in your comparison. Also the cost of the carb hat (kinda expensive)....you wouldn't need one depending on what style throttle body you went with. Also what about the guy starting from scratch. I'm not saying this option is for everyone...it should at least be considered though.
I could efi a motor for $800-900....thats not that bad, and certainly cheaper than a 6-pak setup, etc. Also, that includes a fully adjustable and powerful ignition system.
I'll bow out of this thread now....I didn't mean to take it off topic.
Re: budget turbo Belvedere still alive and well [Re: Quicksilver440] #1373431
01/28/13 12:45 AM
01/28/13 12:45 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
No prob !!!!!
My carb was 35 when I picked it up at a swap meet with what I replaced its 200 with carb purchase included
Carb hat specter, black one 80 bucks
Regulator holley 10 bucks new from eBay
Fuel pump 219.00 shipped to my door BG 400 with new seals eBay
So I prolly have 600 into everything fuel system related, If I can inject my car for that and still run 10s I'm on board
Re: budget turbo Belvedere still alive and well [Re: Quicksilver440] #1373432
01/28/13 01:16 PM
01/28/13 01:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
$50 for a used 750DP, $100 for the prform main body, Can't recall how much the floats and rebuild kit were... I bought the hat on special. It was a plastic unit that Superior was discontinuing I think it was $80. Like I said look around for bargins. You could EFI a motor for 8-900 but could Joe Hotrodder do it? And yes 6-packs aren't cheap. I could have spent less and boosted this engine, but it was already 11.2:1..... Next time.....
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373433
01/28/13 09:03 PM
01/28/13 09:03 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Joe Hotrodder with very little carb tuning experience will pull his hair out trying to tune the thing with a carb and blowtru until he figures it out, as me how I know...EFI especially GM or Megasquirt ecms have alot of support when you get to working with them and a factory style (GM) computer will come closer to keeping itself regulated while your trying to get it figured out, unlike a carb that will go lean and kill your motor without warning. Given I do have more of a background with fuel injection so I guess my opinion might be biased, but there are plenty of places to look for idiot proof step by step wiring diagrams and instructions for low buck EFI systems.
That being said, my car is blowthru carbed but If I had it to do over again I would have saved a few more bucks and went EFI from the start. My car will be EFI soon hopefully with drive by wire and all.
Re: budget turbo Belvedere still alive and well [Re: SLOW67] #1373434
01/28/13 09:41 PM
01/28/13 09:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
???Slow I had zippy boost knowledge and did ok. I let a pro do the carb. Gave him all the specs and it ran perfect out of the box. I only jetted up the rears by 2. I had a few people explain to me how easy it was, and the more I listend the more I wanted to send it out. The next build might be EFI...dunno yet. Depends on cost.
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373435
01/30/13 03:17 AM
01/30/13 03:17 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Carb tuning is a art all its own that's for shure.
Lucky for me I know my way around carbs weather its a rc model to my blow threw stuff
I have never been scared of messing with any carb, that's how you learn
If I did things how its " supposed " to be I wouldn't be running what I have.
For those of you who like the idea of doing your own carb just hit me up.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373436
01/30/13 08:35 AM
01/30/13 08:35 AM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I'm going to take a shot at building a blowthrough carb when I get around to it. I won't be running E85 though.
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373437
01/30/13 10:14 AM
01/30/13 10:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
hey Rock if you ever get pics of the drivers side, the bottom and looking down please post them. I'm noodling a build like that..was going to use 2 turbos but I like how simple yours looks.
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373438
01/30/13 06:08 PM
01/30/13 06:08 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Mperry if your setting your carb up for gas you shouldn't have a problem.
I do have a few more pics of engine compartment but I can't post them it says there to large
Yes how I routed the pipe was verry simple
Making the Y was the hardest, my first attempt looked better but the pipe split so the one on the car don't look as nice but works LOL
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373439
01/30/13 10:22 PM
01/30/13 10:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Flowmaster makes a Y-pipe that's 2x2.5's into a 3" They might even make it into a 3.5. It's not that expensive.
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373440
01/31/13 12:51 AM
01/31/13 12:51 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Art lesson for today LOL
This is a crude drawing of how my pipe is made.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373441
01/31/13 12:55 AM
01/31/13 12:55 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I don't think there is enough room to fit that Flowmaster Y but you could try it or re configure it a bit with some cutting and rewelding
I just figured out how to lower my resolution on my phone.
Once I get it out more pics will be posted !!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373442
02/28/13 05:28 PM
02/28/13 05:28 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Well I tried to make the pic smaller, this is the 383 on the dyno
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373443
02/28/13 05:31 PM
02/28/13 05:31 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I can't wait for this snow to disappear !!!!!!!
I have all the stuff for a few upgrades
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373444
02/28/13 06:41 PM
02/28/13 06:41 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
YES THIS IS AWESOME. I always hated turbo/supercharged cars, but once you own one and start driving it you will realize BOOST IS COOL.
On top of the fact that this turbo is so cheap, you're doing it with a lowly stock 383. I wonder how it would respond to a bigger cam. I know the 4 cylinder turbo cams usually utilize a wide LSA and less duration on the exhaust lobe.
Anyone know how the size of this turbo compares to other, more better known sizes?
Oh and is it a 2 or 4 barrel 383?
Re: budget turbo Belvedere still alive and well [Re: GTX MATT] #1373445
02/28/13 06:57 PM
02/28/13 06:57 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I plan on freshening the 383 up one of these days but for now I'm just having fun with it
It is a 4bbl engine
If I end up going threw it ill look into a more boost type grind
Once you have seat of the pants feel of what the car did NA and what its capable with boost you will never go back !!!!!!
