what are these motor mounts for? #1373331
01/21/13 03:22 AM
01/21/13 03:22 AM
ca
brownout Offline OP
brownout  Offline OP
ca
The mounts came with a 340 I got. not sure what they are for please educate me. the rubber mount is part number 2266
Thanks, Cody
Re: what are these motor mounts for? [Re: brownout] #1373332
01/21/13 03:23 AM
01/21/13 03:23 AM
ca
brownout Offline OP
brownout  Offline OP
ca
pic 2
Re: what are these motor mounts for? [Re: brownout] #1373333
01/21/13 03:23 AM
01/21/13 03:23 AM
ca
brownout Offline OP
brownout  Offline OP
ca
3
Re: what are these motor mounts for? [Re: brownout] #1373334
01/21/13 03:39 AM
01/21/13 03:39 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like A body mounts to me...
Re: what are these motor mounts for? [Re: brownout] #1373335
01/21/13 04:29 AM
01/21/13 04:29 AM
1967 to 1972 and some early 1973 A motor for A bodys. 1973 Mopar chnaged the K members and motor mounts to the spool type, some early A body cars got the old style until they where used up is what I have heard, I had a 1973 Dart Sport 340 car that had the earlier K member in it
Re: what are these motor mounts for? [Re: 1_WILD_RT] #1373336
01/21/13 04:33 AM
01/21/13 04:33 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yep.
68-72 A-body 340 motor mount brackets. IIRC, its the drivers side that is special for 340 block (and 360). The other side is the same as 273 or 318. The rubber insulators are the same as other 67-72 small blocks.
Those brackets are availible very good repro brand new powder coated. Used value on those does not generally exceed new repo value.
Re: what are these motor mounts for? [Re: autoxcuda] #1373337
01/21/13 01:32 PM
01/21/13 01:32 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Oh don't get greg purcell started on this that A body brackets never had 4 bolts...
Those sure look like they'd work on a 67-72 273-318 engine.
First pic, top bracket is pass side.
Re: what are these motor mounts for? [Re: RobX4406] #1373338
01/21/13 01:45 PM
01/21/13 01:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I assumed since they came on a 340 they were 340 brackets. Not a good assumption.
So are those 340 brackets or 273/318?
Re: what are these motor mounts for? [Re: autoxcuda] #1373339
01/21/13 02:12 PM
01/21/13 02:12 PM
RobX4406 Offline
RobX4406  Offline
Brackets appear to be same width, not more narrow on drivers side like ears on production 340-360 blocks.
The easy way to fix it is use a nut or shim stock to narrow up the width.
