Drag link length on straight axel
#1373274
01/21/13 01:00 AM
01/21/13 01:00 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Question...
Straight axel ford F3 truck, talking drag link from pitman arm to steering link on kingpin, drag link running parallel to frame. No other suspension mods. I had to move my steering box aprx 3 1/2" forward in the frame to clear an 12v cummins transplant, effectively making my drag link shortened from 12" center to center to aprx 9" (havent finalized the chop yet).
What will be the negatives?
Angle was not change nor travel limited.
Educate me.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Drag link length on straight axel
[Re: kilroy]
#1373275
01/21/13 01:07 AM
01/21/13 01:07 AM
kilroy
Iowa State fan
heres a pic of the rough up, Im a little further along now.
[Re: poorboy]
#1373278
01/22/13 01:10 AM
01/22/13 01:10 AM
kilroy
Iowa State fan
Poorboy,
can you correct this, or what is the work around?
The center point should just be at the point of the center of the arc swing of the pitman arm? Find the center of lock to lock and build from there?
[Re: kilroy]
#1373282
01/24/13 04:19 PM
01/24/13 04:19 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A short drag link will probably result in some pretty severe bump steer.
One way to lengthen the drag link is to have the rod on the pitman arm go to the rear and connect to a frame-mounted idler that the actual drag link hooks to.
