block porn it's here
#1372960
01/20/13 09:15 PM
01/20/13 09:15 PM
Posts: 2,408 Ambridge, Pa.
rickraw
Ambridge, Pa.
picked it up yesterday.
Re: block porn it's here
[Re: rickraw]
#1372961
01/20/13 09:25 PM
01/20/13 09:25 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I need more explicit pics please.
[Re: rickraw]
#1372965
01/20/13 10:10 PM
01/20/13 10:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i don't know how to post multiple picks. never done it before.
If you want you can just click on reply (on your first post) then put a number or something in the comment area(as in .. 2 or what ever you want) then hit enter... on the post preview hit the browse and find your pic on the puter then enter the pic You need to have the preview box checked on the first page(below your continue button)
[Re: rickraw]
#1372969
01/20/13 10:21 PM
01/20/13 10:21 PM
MR_P_BODY
thanks mr.p. i'll see if i can post up some more pics of build.
No problem.... thats a nice block... whats the max bore
[Re: rickraw]
#1372970
01/20/13 10:25 PM
01/20/13 10:25 PM
MR_P_BODY
I just noticed that there isnt a oil sending unit hole... thats different... where are you picking up the oil pressure
[Re: rickraw]
#1372972
01/20/13 11:23 PM
01/20/13 11:23 PM
MR_P_BODY
I see that it has the cam bearings in it already... are they 50mm or 60mm ... also is it lined bored already for a crank... if you dont mind... what the cost on that .. PM me if you want... one more thing.. whats the deck height .... thanks.. I'm sorta looking for a new block
[Re: rickraw]
#1372973
01/20/13 11:28 PM
01/20/13 11:28 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
4.250max bore.. push rod oiling..the oil galley in the cam tunnel is like a chevy .. it is drilled right throught the center of the lifter .. in stead of be hind.. this fixed a bunch of kents problems
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: MR_P_BODY]
#1372974
01/20/13 11:31 PM
01/20/13 11:31 PM
WHITEDART
bean town ....Ca
I think 9.600 deck and I think 4.600 bore space .
[Re: WHITEDART]
#1372975
01/20/13 11:37 PM
01/20/13 11:37 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I know his old r3 block was 9.2 so I assume this is the same.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: WHITEDART]
#1372976
01/20/13 11:40 PM
01/20/13 11:40 PM
WHITEDART
bean town ....Ca
what is the last main cap on this block set up for a 360 pan or 340 good luck with your build check all your oiling and water really close
[Re: WHITEDART]
#1372977
01/21/13 08:54 PM
01/21/13 08:54 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I don't think they are going 4.250" with the aluminum block. There was talk of a coating on the cylinder wall that would allow larger bores with the aluminum. I talked with an engine builder who has done a lot of mountain motors with the coating. He said does not get along with nitrous.
Better check on that 4.600" bore spacing. I am fairly sure that is not correct. I beleive it is 4.440" bore spacing, same as stock.
Leon
