Page 1 of 3 1 2 3
block porn it's here #1372960
01/20/13 09:15 PM
01/20/13 09:15 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
picked it up yesterday.
Re: block porn it's here [Re: rickraw] #1372961
01/20/13 09:25 PM
01/20/13 09:25 PM
Guitar Jones Offline
I need more explicit pics please.
Re: block porn it's here [Re: rickraw] #1372962
01/20/13 09:36 PM
01/20/13 09:36 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
With one hand I bet.
Very nice indeed.
Re: block porn it's here [Re: Guitar Jones] #1372963
01/20/13 09:44 PM
01/20/13 09:44 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
i don't know how to post multiple picks. never done it before.
Re: block porn it's here [Re: rickraw] #1372964
01/20/13 10:00 PM
01/20/13 10:00 PM
Q
Quicktree Offline
Quicktree  Offline
Q
just keep adding the links
Re: block porn it's here [Re: rickraw] #1372965
01/20/13 10:10 PM
01/20/13 10:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want you can just click on reply (on your
first post) then put a number or something in the
comment area(as in .. 2 or what ever you want) then
hit enter... on the post preview hit the browse and
find your pic on the puter then enter the pic
You need to have the preview box checked on the first
page(below your continue button)
Re: block porn it's here [Re: rickraw] #1372966
01/20/13 10:13 PM
01/20/13 10:13 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
2
Re: block porn it's here [Re: rickraw] #1372967
01/20/13 10:14 PM
01/20/13 10:14 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
3
Re: block porn it's here [Re: MR_P_BODY] #1372968
01/20/13 10:17 PM
01/20/13 10:17 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
thanks mr.p. i'll see if i can post up some more pics of build.
Re: block porn it's here [Re: rickraw] #1372969
01/20/13 10:21 PM
01/20/13 10:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No problem.... thats a nice block... whats the max bore
Re: block porn it's here [Re: rickraw] #1372970
01/20/13 10:25 PM
01/20/13 10:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just noticed that there isnt a oil sending unit hole...
thats different... where are you picking up the oil pressure
Re: block porn it's here [Re: MR_P_BODY] #1372971
01/20/13 10:53 PM
01/20/13 10:53 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
don't know max bore size, kent is calling me tomorrow nite, i'll ask. block has priority oiling on the china wall. i might get the pressure down by the filter.
Re: block porn it's here [Re: rickraw] #1372972
01/20/13 11:23 PM
01/20/13 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I see that it has the cam bearings in it already...
are they 50mm or 60mm ... also is it lined bored already
for a crank... if you dont mind... what the cost on
that .. PM me if you want... one more thing.. whats
the deck height .... thanks.. I'm sorta looking for
a new block
Re: block porn it's here [Re: rickraw] #1372973
01/20/13 11:28 PM
01/20/13 11:28 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
4.250max bore.. push rod oiling..the oil galley in the cam tunnel is like a chevy .. it is drilled right throught the center of the lifter .. in stead of be hind.. this fixed a bunch of kents problems
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: block porn it's here [Re: MR_P_BODY] #1372974
01/20/13 11:31 PM
01/20/13 11:31 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I think 9.600 deck and I think 4.600 bore space .
Re: block porn it's here [Re: WHITEDART] #1372975
01/20/13 11:37 PM
01/20/13 11:37 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I know his old r3 block was 9.2 so I assume this is the same.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: block porn it's here [Re: WHITEDART] #1372976
01/20/13 11:40 PM
01/20/13 11:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
what is the last main cap on this block set up for a 360 pan or 340 good luck with your build check all your oiling and water really close
Re: block porn it's here [Re: WHITEDART] #1372977
01/21/13 08:54 PM
01/21/13 08:54 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I don't think they are going 4.250" with the aluminum block. There was talk of a coating on the cylinder wall that would allow larger bores with the aluminum. I talked with an engine builder who has done a lot of mountain motors with the coating. He said does not get along with nitrous.
Better check on that 4.600" bore spacing. I am fairly sure that is not correct. I beleive it is 4.440" bore spacing, same as stock.
Leon
Re: block porn it's here [Re: Leon441] #1372978
01/21/13 09:08 PM
01/21/13 09:08 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Leon
hey leon I think we are both wrong... I think 4.460 on the bore spacing I had a brain fart ..but this block looks like iron so 4.250.would be right..
Re: block porn it's here [Re: WHITEDART] #1372979
01/21/13 09:58 PM
01/21/13 09:58 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Looks nice Rick! Is that a Ritter block?
Page 1 of 3 1 2 3
