EFI FUEL MANAGEMENT #1372929
01/20/13 09:08 PM
01/20/13 09:08 PM
Hickory, NC
Luke Offline OP
Luke  Offline OP
Hickory, NC
Looking for advise, building high speed road race early a, r3, w9's, large cubic inches
Need EFI advise, 1100/1200 hps twin turbo, what the best EFI management system, looking to have 3 or 4 different tunes loaded depending on need, traction control, also looking to possibly add chassis sensors
Considering the new fast system, really like the Ems systems
Pros and cons
Luke
Re: EFI FUEL MANAGEMENT [Re: Luke] #1372930
01/20/13 09:35 PM
01/20/13 09:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You NEED to speak with Rich http://www.fastmanefi.com/
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: EFI FUEL MANAGEMENT [Re: hemi-itis] #1372931
01/21/13 12:39 AM
01/21/13 12:39 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have FAST on two diffrent cars. I like it.
Re: EFI FUEL MANAGEMENT [Re: Luke] #1372932
01/21/13 04:16 AM
01/21/13 04:16 AM
On your deal I would look at either Motech or Big Stuff 3 What type of intercooling are you going to use, air to air or air to water
Re: EFI FUEL MANAGEMENT [Re: Cab_Burge] #1372933
01/21/13 04:39 AM
01/21/13 04:39 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Why to use BigStuff3 when there is FAST XFi? Motec is very expencive but one of the best
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: EFI FUEL MANAGEMENT [Re: Georg] #1372934
01/21/13 11:59 AM
01/21/13 11:59 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Fast, all the way. Use fast on mine and all my customers. I'm in NC also if you need any help pm me.
One day I will have something cool here.
Re: EFI FUEL MANAGEMENT [Re: sdaurity] #1372935
01/21/13 12:23 PM
01/21/13 12:23 PM
nc
cold85 Offline
cold85  Offline
nc
We have switched to bigstuff due to fast crashing and them trying to charge a arm and leg to fix have yall not had any of those problems?
Re: EFI FUEL MANAGEMENT [Re: cold85] #1372936
01/21/13 01:26 PM
01/21/13 01:26 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Never had a problem once. The only thing I have ever had a problem with was the external logger on the old classics but haven't used one of them in years. The few guys I know with them just ride with the laptop to log now. Paul gets me prob 4-5 units a year for customer installs and I take to him to use dyno and help get tuned in. Doing one now on Brad Marsh's ultra/true street car to get ready for Georgia.
Re: EFI FUEL MANAGEMENT [Re: sdaurity] #1372937
01/21/13 01:37 PM
01/21/13 01:37 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I have a FAST XFI system with traction caontrol and Internal data logging options. I also have the FAST DASH for expanded data logging capabilities and the optional 3 axis accelerometer, 8 channel EGT module, and GPS sensor. I found the GPS sensor logging rate to be to slow for drag racing but would probably be really handy for road racing since it will plot lap times and actual road speed at any point on the road coarse and plot the actual path traveled. Both the FAST XFI and DASH have 8 aux. analog inputs and 2 speed sensor chanels to log with. You can even use the XFI to control boost. The XFI internal data logger memmory is limited and would recomend the DASH logger for long duration data logging. Also, FAST has a thumbwheel switch that would allow changing the tune very easy without the laptop.
I would recomend downloading the software from FAST and navigate your way through and see if you like it. I don't have any experience with the others but I'm sure they all have there software as a free download for you to try.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: EFI FUEL MANAGEMENT [Re: Luke] #1372938
01/21/13 01:55 PM
01/21/13 01:55 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Pros and cons
Luke
I'm here. Call me at 209-247-6497
I can discuss pros and cons of the systems mentioned.
Re: EFI FUEL MANAGEMENT [Re: Georg] #1372939
01/21/13 04:16 PM
01/21/13 04:16 PM
Hickory, NC
Luke Offline OP
Luke  Offline OP
Hickory, NC
air to liguid
thanks
Luke
Re: EFI FUEL MANAGEMENT [Re: Luke] #1372940
01/21/13 06:40 PM
01/21/13 06:40 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
holley hp or holley dominator
Re: EFI FUEL MANAGEMENT [Re: prochargedhemi] #1372941
01/21/13 06:57 PM
01/21/13 06:57 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Motec is what you need
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: EFI FUEL MANAGEMENT [Re: bigtimeauto] #1372942
01/22/13 09:23 AM
01/22/13 09:23 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
An engine is what you need.....LOL
Re: EFI FUEL MANAGEMENT [Re: joshking440] #1372943
01/22/13 03:35 PM
01/22/13 03:35 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Fast, Motec, BigStuff3 will probably all meet your needs ....
It really comes down to support or your level of expertise. Iif your not comfortable in using the system, then you need a system that your tuner is comfortable with or one that will provide the exact support, as & when you need it.
Re: EFI FUEL MANAGEMENT [Re: joshking440] #1372944
01/22/13 06:39 PM
01/22/13 06:39 PM
Hickory, NC
Luke Offline OP
Luke  Offline OP
Hickory, NC
not sure if i understand the comment, r3 block, w9 heads, mopar intake, wilson elbow and tbi, scat crank and rods, JE pistons, kevco custom pan, thought i was well on my way engine wise...
6 speed tremec, moser rear db axle, alterktion front and lynx rear suspension,Wildwood brakes, 22 point cage, full tubs, etc
pretty well on my way with the car as well...lol
Luke
Re: EFI FUEL MANAGEMENT [Re: mopar_mark] #1372945
01/22/13 06:44 PM
01/22/13 06:44 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Or MegaSquirt.
Scott Clark aka 'DieselGeek' knows his way well around these setups in Dragracing, EngineMasters and LandSpeedRacing.
Re: EFI FUEL MANAGEMENT [Re: Luke] #1372946
01/22/13 06:56 PM
01/22/13 06:56 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Luke
I'm pretty sure he meant me. my Motec is sitting here because my good engine is apart.
Re: EFI FUEL MANAGEMENT [Re: BigBlockMopar] #1372947
01/22/13 07:52 PM
01/22/13 07:52 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I have to admit to being a total novice at EFI tuning...
but I am pretty impressed with MegaSquirt's (TunerStudio) ability to "learn" and correct my AFRs to my selected target numbers - just by driving it and clicking OK once in a while. You still need to set everything else, but for a novice it's a pretty sweet system.
Re: EFI FUEL MANAGEMENT [Re: bigtimeauto] #1372948
01/22/13 08:02 PM
01/22/13 08:02 PM
Hickory, NC
Luke Offline OP
Luke  Offline OP
Hickory, NC
Luke
ok, im new here, as if you couldnt tell...lol
Luke
