EFI FUEL MANAGEMENT
#1372929
01/20/13 09:08 PM
01/20/13 09:08 PM
Posts: 22 Hickory, NC
Luke
Hickory, NC
Looking for advise, building high speed road race early a, r3, w9's, large cubic inches Need EFI advise, 1100/1200 hps twin turbo, what the best EFI management system, looking to have 3 or 4 different tunes loaded depending on need, traction control, also looking to possibly add chassis sensors Considering the new fast system, really like the Ems systems Pros and cons Luke
Re: EFI FUEL MANAGEMENT
[Re: Georg]
#1372934
01/21/13 11:59 AM
01/21/13 11:59 AM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Fast, all the way. Use fast on mine and all my customers. I'm in NC also if you need any help pm me.
One day I will have something cool here.
[Re: sdaurity]
#1372935
01/21/13 12:23 PM
01/21/13 12:23 PM
Posts: 452 nc
cold85
nc
We have switched to bigstuff due to fast crashing and them trying to charge a arm and leg to fix have yall not had any of those problems?
[Re: sdaurity]
#1372937
01/21/13 01:37 PM
01/21/13 01:37 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I have a FAST XFI system with traction caontrol and Internal data logging options. I also have the FAST DASH for expanded data logging capabilities and the optional 3 axis accelerometer, 8 channel EGT module, and GPS sensor. I found the GPS sensor logging rate to be to slow for drag racing but would probably be really handy for road racing since it will plot lap times and actual road speed at any point on the road coarse and plot the actual path traveled. Both the FAST XFI and DASH have 8 aux. analog inputs and 2 speed sensor chanels to log with. You can even use the XFI to control boost. The XFI internal data logger memmory is limited and would recomend the DASH logger for long duration data logging. Also, FAST has a thumbwheel switch that would allow changing the tune very easy without the laptop. I would recomend downloading the software from FAST and navigate your way through and see if you like it. I don't have any experience with the others but I'm sure they all have there software as a free download for you to try. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Luke]
#1372938
01/21/13 01:55 PM
01/21/13 01:55 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I'm here. Call me at 209-247-6497 I can discuss pros and cons of the systems mentioned.
[Re: Georg]
#1372939
01/21/13 04:16 PM
01/21/13 04:16 PM
Luke
Hickory, NC
On your deal I would look at either Motech or Big Stuff 3 What type of intercooling are you going to use, air to air or air to water
Why to use BigStuff3 when there is FAST XFi? Motec is very expencive but one of the best
air to liguid thanks Luke
[Re: bigtimeauto]
#1372942
01/22/13 09:23 AM
01/22/13 09:23 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Motec is what you need
An engine is what you need.....LOL
[Re: joshking440]
#1372944
01/22/13 06:39 PM
01/22/13 06:39 PM
Luke
Hickory, NC
not sure if i understand the comment, r3 block, w9 heads, mopar intake, wilson elbow and tbi, scat crank and rods, JE pistons, kevco custom pan, thought i was well on my way engine wise...
6 speed tremec, moser rear db axle, alterktion front and lynx rear suspension,Wildwood brakes, 22 point cage, full tubs, etc
pretty well on my way with the car as well...lol
Luke
[Re: Luke]
#1372946
01/22/13 06:56 PM
01/22/13 06:56 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Luke
I'm pretty sure he meant me. my Motec is sitting here because my good engine is apart.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1372948
01/22/13 08:02 PM
01/22/13 08:02 PM
Luke
Hickory, NC
Luke
ok, im new here, as if you couldnt tell...lol Luke
