How many fasteners to hold a fiberglass hood on? #1372477
01/19/13 10:33 PM
01/19/13 10:33 PM
Santa Cruz, California
Lefty Offline OP
Lefty  Offline OP
I have not installed a lift off fiberglass hood since the 70's. Back then I used three Dzus fasteners down each side of the hood. It never blew off, but would buldge above 100 mph and make me nervous.
What are you guys using now days? It's going on a 66 Coronet.
Re: How many fasteners to hold a fiberglass hood on? [Re: Lefty] #1372478
01/19/13 10:42 PM
01/19/13 10:42 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Lots......
Re: How many fasteners to hold a fiberglass hood on? [Re: jim sciortino] #1372479
01/19/13 10:47 PM
01/19/13 10:47 PM
Arizona
Chris'sBarracuda Offline
Arizona
Mine has a dozen, plus the scoop hold downs make 16..
Chris..
Re: How many fasteners to hold a fiberglass hood on? [Re: Lefty] #1372480
01/19/13 10:55 PM
01/19/13 10:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run 5 down each side... none on the front because
of the shape and 3 on the scoop... this is on a carbon
fiber hood so it doesnt bow
Re: How many fasteners to hold a fiberglass hood on? [Re: MR_P_BODY] #1372481
01/19/13 11:17 PM
01/19/13 11:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Depends on the hood. Last one used 7 Dzus. Watched a guy with a fire and know one had a tool handy to remove the hood. New hood is stiffer,4 pins.
Doug
Re: How many fasteners to hold a fiberglass hood on? [Re: Lefty] #1372482
01/19/13 11:24 PM
01/19/13 11:24 PM
It really depends on the scoop and how much MPH the scoop will see SS hemi type scoop at 120 MPH stays on my car nicely with 6 Dzuz and the two original hood hinge arms bolted to the sides of the hood. At 135 MPH the darn Hemi SS scoop is trying to rip the hood off of the car I only have two bolts holding the front of the scoop on the hood due to running a six pak originally, it might've been better with four bolts on the front like the original 1968 SS Hemi scoop are
Re: How many fasteners to hold a fiberglass hood on? [Re: dvw] #1372483
01/19/13 11:25 PM
01/19/13 11:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I'm using on the Rampage... ordered 2
sets the other day... plus the hood is on hinges that
I am making it to slide off the hinges.. so it'll
bee both hinged and a take off
http://www.deftracing.com/aerocatch_hood_pins/aerocatch_plus_flush_hood_latches.htm
Re: How many fasteners to hold a fiberglass hood on? [Re: MR_P_BODY] #1372484
01/20/13 02:13 AM
01/20/13 02:13 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Joe
Without Data, you’re just another guy with an opinion.
Re: How many fasteners to hold a fiberglass hood on? [Re: sr4440] #1372485
01/20/13 04:59 AM
01/20/13 04:59 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine both have 14 on the hood..
Re: How many fasteners to hold a fiberglass hood on? [Re: Al_Alguire] #1372486
01/20/13 06:18 AM
01/20/13 06:18 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
mines made from Kevlar. only uses 6 to hold the whole thing on. but then Kevlar doesn't flex & it's lighter.
Re: How many fasteners to hold a fiberglass hood on? [Re: rebel] #1372487
01/20/13 02:10 PM
01/20/13 02:10 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Mine has 10, 3 down each side and 2 in front and 2 in rear
Re: How many fasteners to hold a fiberglass hood on? [Re: SB412DUSTER] #1372488
01/20/13 04:17 PM
01/20/13 04:17 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Only IF you would buy some decent fiberglass maybe you wouldn't need a huNdred fasteners to hold-it-down. I have had my streeter 62 up-to 5400 in high-gear with a 2.76 gear .... with FOUR PINS at it was fine.
But I did have some super-trix Mr FLAPPERgas bracing in it ...
Re: How many fasteners to hold a fiberglass hood on? [Re: dOc !] #1372489
01/22/13 12:30 AM
01/22/13 12:30 AM
Lefty Offline OP
Lefty  Offline OP
I'll bite...
Who makes "decent" 66 Coronet fiberglass these days...
