HEMI VALVE COVER BREATHER LOCATION???? #1372215
01/19/13 12:28 PM
01/19/13 12:28 PM
Great Neck,LI,new york
hemi-itis Offline OP
I purchased a set of aluminum sheet metal valve covers and a pair of breather/oil separators that will also be used later down the road when I install a vacume pump.So my question to you all is,,,,,,where is the sweet spot to install the breathers on the covers.For now the breathers will go from the valve cover to a puke tank for each side.
I'll post some pics later.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372216
01/19/13 12:29 PM
01/19/13 12:29 PM
The puke tank.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372217
01/19/13 04:55 PM
01/19/13 04:55 PM
I would want them as far forward as possible and as far away from a rocker arm tips as possible,not symetrical I would also put a baffle under where they are The bad thing about putting in two breathers now and then having to seal them up later with the vacume pump is why do it twice? I think I would run the covers I have now and use the new ones later when the vacume pump went on But I'm lazy also
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: Cab_Burge] #1372218
01/19/13 05:08 PM
01/19/13 05:08 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The best place to put them is as high up and away from the rockers as you can get them.On the cast covers they were located at the top and in the middle similar to the old F/D setups.Make sure to use baffeled breathers.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: B G Racing] #1372219
01/20/13 01:06 AM
01/20/13 01:06 AM
The Moroso oil/air separator is quite tall with baffleing material in the middle.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372220
01/20/13 01:07 AM
01/20/13 01:07 AM
Top unscrews to add oil.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372221
01/20/13 01:09 AM
01/20/13 01:09 AM
One for each side.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372222
01/20/13 01:11 AM
01/20/13 01:11 AM
I've been wanting these valve covers for a LONG time
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372223
01/20/13 06:53 AM
01/20/13 06:53 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I have a few sets but those long bolts are a pain so on my latest set I opened the bolt holes on the tubes to let a much shorter allen head with a washer.
I do not like the look with the bolt tubes sticking out so the next set I may cut them flush with the cover
home of the
Sox and Martin Hemi Duster
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: HEMIFRED] #1372224
01/20/13 08:45 PM
01/20/13 08:45 PM
Went looking for hardware today and came up with nothing
Had to massage the firewall to get the right side cover on.The left side,had to modify the throttle bracket that bolts to the side of the blower.
Fred,we sunk the allen head further into the tube,just not as far as you did.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372225
01/20/13 09:11 PM
01/20/13 09:11 PM
Also have interferance with the shock bolt
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372226
01/20/13 11:07 PM
01/20/13 11:07 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
put mine up front.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: 68 HEMI GTS] #1372227
01/20/13 11:21 PM
01/20/13 11:21 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Up front.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372228
01/20/13 11:56 PM
01/20/13 11:56 PM
Any tricks for the shock bolt?????????????????????
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372229
01/20/13 11:57 PM
01/20/13 11:57 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
And, they include a tire sidewall scouring pad. Nice!!!
Hemi-itis, you can see here where I put my burndown breathers. Never picked up oil in those locations.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: hemi-itis] #1372230
01/21/13 12:04 AM
01/21/13 12:04 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Have to remove the P/S shock bolt to remove the cover!
I mounted mine high and in the rear by the firewall. Hate looking at the breathers myself!
Who's covers are those?
SS/DA 1924
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: DusterDave] #1372231
01/21/13 12:04 AM
01/21/13 12:04 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
AL, can u cut the shock bolt ....had to do it for my fender well headers on my 68rr....pat
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: SSDAcuda] #1372232
01/21/13 12:06 AM
01/21/13 12:06 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Dave, are those mag. covers?
SS/DA 1924
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: SSDAcuda] #1372233
01/21/13 12:09 AM
01/21/13 12:09 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
No, just Stage V cast aluminum covers that were powder coated to look like Dow coated magnesium.
Re: HEMI VALVE COVER BREATHER LOCATION???? [Re: SSDAcuda] #1372234
01/21/13 09:46 AM
01/21/13 09:46 AM
They are AH-SO covers
I'm thinkin of moving the shock bolt hole outwards towards the tires.Will that mess up the geomotry??
