HEMI VALVE COVER BREATHER LOCATION????
#1372215
01/19/13 12:28 PM
01/19/13 12:28 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I purchased a set of aluminum sheet metal valve covers and a pair of breather/oil separators that will also be used later down the road when I install a vacume pump.So my question to you all is,,,,,,where is the sweet spot to install the breathers on the covers.For now the breathers will go from the valve cover to a puke tank for each side. I'll post some pics later.
Re: HEMI VALVE COVER BREATHER LOCATION????
[Re: hemi-itis]
#1372217
01/19/13 04:55 PM
01/19/13 04:55 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I would want them as far forward as possible and as far away from a rocker arm tips as possible,not symetrical I would also put a baffle under where they are The bad thing about putting in two breathers now and then having to seal them up later with the vacume pump is why do it twice? I think I would run the covers I have now and use the new ones later when the vacume pump went on But I'm lazy also
[Re: B G Racing]
#1372219
01/20/13 01:06 AM
01/20/13 01:06 AM
hemi-itis
The Moroso oil/air separator is quite tall with baffleing material in the middle.
[Re: HEMIFRED]
#1372224
01/20/13 08:45 PM
01/20/13 08:45 PM
hemi-itis
Went looking for hardware today and came up with nothing Had to massage the firewall to get the right side cover on.The left side,had to modify the throttle bracket that bolts to the side of the blower. Fred,we sunk the allen head further into the tube,just not as far as you did.
