Upper ball joint #1371933
01/18/13 05:54 PM
01/18/13 05:54 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
Which way do the upper ball joints thread? Left or just normal screw in right?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Upper ball joint [Re: CurYellowBird] #1371934
01/18/13 06:09 PM
01/18/13 06:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Righthand thread. Just start it as straight as you can and crank it down. There is a torque spec in shop manuals that it needs to reach to be tight enough. (If it keeps spinning brfore that torque is reached, the arm is no good)
Re: Upper ball joint [Re: buildanother] #1371935
01/18/13 06:20 PM
01/18/13 06:20 PM
P
Paul_Fancsali Offline
P
Get out the welder bet you have to do some tacking
Re: Upper ball joint [Re: Paul_Fancsali] #1371936
01/18/13 09:39 PM
01/18/13 09:39 PM
San Antonio, TX
San Antonio, TX
I spent a couple hours and used enough PB blaster to kill a horse. Been working on the front end since 10 this morning. I've decided the only way to get this done is to take the socket and control arm with me and have a shop get the damn thing out. Might as well do the control arm bushings at the same time too.
Re: Upper ball joint [Re: CurYellowBird] #1371937
01/19/13 02:12 AM
01/19/13 02:12 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I have used a 3/4 inch breaker bar with a 8ft pipe to break it loose.
and the last car I did, I used my IR 2131 1/2 impact set on KILL and they came out...no fun..
the bushings are no fun either...
Re: Upper ball joint [Re: sthemi] #1371938
01/19/13 02:41 AM
01/19/13 02:41 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The first ones I took out I used good size pipe wrench with a pipe on the end. They came out hard. New ones went in easy, used the same pipe wrench without the pipe.
Re: Upper ball joint [Re: CurYellowBird] #1371939
01/19/13 06:16 AM
01/19/13 06:16 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Remove upper ball joint with an impact wrench. That's what a repair shop will do.
Remove/install UCA bushings with a large diameter threaded rod, nuts, and spacers. Not a snap, but not too hard. Or use this kit:
http://www.americanmuscle.biz/Suspension_Tools_s/1.htm
Re: Upper ball joint [Re: CurYellowBird] #1371940
01/19/13 10:20 AM
01/19/13 10:20 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
It may very well be harder to get it out if you remove the UCA from the car. Use an impact wrench and heat, it will come out. When installing the new ball joint use care to start the threads evenly. Mininum torque is 125 ft. lbs. I shoot for 150.
Re: Upper ball joint [Re: CurYellowBird] #1371941
01/19/13 01:29 PM
01/19/13 01:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you do go to a shop make sure they know they SCREW OUT , if they press them out your arm is JUNK .
Re: Upper ball joint [Re: JohnRR] #1371942
01/20/13 09:49 AM
01/20/13 09:49 AM
pasadena,md
red 69 runner Offline
pasadena,md
I removed my old ones with a pipe wrench.when I put the new ones in one side I was able to thread all the way in by hand but the other side I needed a socket ($27.00 at NAPA,they had it on the shelf)since the 1 side went in so easy I just had both tacked in after torking for safety.if i ever have to replace them again i will probably just buy new upper control arms.
