Upper ball joint
#1371933
01/18/13 05:54 PM
01/18/13 05:54 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
Which way do the upper ball joints thread? Left or just normal screw in right?
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
Re: Upper ball joint
[Re: Paul_Fancsali]
#1371936
01/18/13 09:39 PM
01/18/13 09:39 PM
CurYellowBird
San Antonio, TX
I spent a couple hours and used enough PB blaster to kill a horse. Been working on the front end since 10 this morning. I've decided the only way to get this done is to take the socket and control arm with me and have a shop get the damn thing out. Might as well do the control arm bushings at the same time too.
Project War Bird:
GY3 Curious yellow
All original
[Re: CurYellowBird]
#1371937
01/19/13 02:12 AM
01/19/13 02:12 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I have used a 3/4 inch breaker bar with a 8ft pipe to break it loose. and the last car I did, I used my IR 2131 1/2 impact set on KILL and they came out...no fun.. the bushings are no fun either...
[Re: CurYellowBird]
#1371941
01/19/13 01:29 PM
01/19/13 01:29 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
If you do go to a shop make sure they know they SCREW OUT , if they press them out your arm is JUNK .
