is it worth chasing? #1371906
01/18/13 05:34 PM
01/18/13 05:34 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
just before xmas i bought a few spare parts to keep my racing alive should we have a mishap. one item was an Indy rocker arm for my -1 heads. the intake rocker i swapped out had a minor bit of damage from the pushrod on the exhaust which had a minor failure with the lash cap. the new rocker arm had only done 8 runs before the wheel fell in half & momentarily caused the valve to clip the piston. i'm running a small roller with moderate spring pressures 240 seat, 550 spring rate. none of my other rocker arms have had this failure. do you think i should go to ICH & demand a replacement or is this a suck it up deal coz it's dragracing? cost me 0.010 on a run that lost me the race
Re: is it worth chasing? [Re: rebel] #1371907
01/18/13 06:17 PM
01/18/13 06:17 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Well I wouldnt demand one, but.....if you called me and explained the situation, and asked nicely I would send you a new one....
Re: is it worth chasing? [Re: rebel] #1371908
01/18/13 06:19 PM
01/18/13 06:19 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Are these the rockers I sent out to Bob Mazzolinis for overnight for you??
Re: is it worth chasing? [Re: joshking440] #1371909
01/18/13 06:30 PM
01/18/13 06:30 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
yes it is Josh, the one n the same. i had to put the damaged one i removed back into service.
Re: is it worth chasing? [Re: joshking440] #1371910
01/18/13 06:36 PM
01/18/13 06:36 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
hey Josh when this rocker arrived we noted the adjuster uses a larger allen key size, is this what the new rockers are using now? if it is i'm thinking i should upgrade my existing arms with this size as the smaller ones tend to wear out the hex faster.
Re: is it worth chasing? [Re: rebel] #1371911
01/18/13 06:43 PM
01/18/13 06:43 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Yes, we went to the larger Hex on all of our adjusters. We have small hex still, so if you want them all to match, we can do that as well.
You sure you didnt have out your .200 feel gauge rather than the .020...
Re: is it worth chasing? [Re: joshking440] #1371912
01/18/13 06:50 PM
01/18/13 06:50 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
josh...... is truly one of the best things indy has ever done,,,,,customer service...AAAAAAA+++++++ pat
Re: is it worth chasing? [Re: pattyboy 572] #1371913
01/18/13 08:00 PM
01/18/13 08:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Indy, this. WOW. Josh I'm impressed.
Doug
Re: is it worth chasing? [Re: joshking440] #1371914
01/18/13 08:13 PM
01/18/13 08:13 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
100% sure. after the wheel fell off we probably had close to .200 clearence. this happened at 2nd round eliminations & we had done a valve clearence check & retorque just after qualifying. didn't see anything different at that check but then i wasn't checking the rocker arm wheels with a microscope looking for stress cracks. we have now tho, everything seems to be all ok, just this one had a bad day at the track. will e-mail your work address on Monday so we can discuss what we get sent down under. thanx dude. as the others have commented, it's great to see some service now.
Re: is it worth chasing? [Re: rebel] #1371915
01/19/13 12:13 AM
01/19/13 12:13 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Regardless of weather or not you get a free replacement, or whatever, I would contact Indy and explain what happened and offer to ship them the part back.
Any company worth their salt would want that rocker to look at and review it to ensure they dont have a problem with a batch of them. Thats part of the quality control/improvement process.
Re: is it worth chasing? [Re: NTOLERANCE] #1371916
01/19/13 01:04 PM
01/19/13 01:04 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Nice to see some customer service from Indy .
Re: is it worth chasing? [Re: viperblue72] #1371917
02/16/13 04:56 AM
02/16/13 04:56 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
does Josh still work @ ICH? so far i've recieved nothing from them & Josh doesn't answer my e-mails.
getting close to a month now, do you think it's just bussiness as usual for ICH?
Re: is it worth chasing? [Re: rebel] #1371918
02/16/13 05:16 AM
02/16/13 05:16 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Re: is it worth chasing? [Re: Tig] #1371919
02/16/13 08:04 AM
02/16/13 08:04 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Re: is it worth chasing? [Re: B G Racing] #1371920
02/16/13 08:31 AM
02/16/13 08:31 AM
tboomer Online work
tboomer  Online Work
Re: is it worth chasing? [Re: tboomer] #1371921
02/16/13 01:07 PM
02/16/13 01:07 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I've been running around here it's hard for me to get in front of an email.
Ill get your rockers out Monday.
Just call if you need anything.
Re: is it worth chasing? [Re: joshking440] #1371922
02/16/13 01:09 PM
02/16/13 01:09 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Also reb can you send those back to me that broke so I can have them looked at.
Re: is it worth chasing? [Re: joshking440] #1371923
02/17/13 03:17 AM
02/17/13 03:17 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
no rush Josh, it's only our race season down under, the fact that i had to put my damaged rocker back in doesn't play on my mind at all when racing.
Re: is it worth chasing? [Re: rebel] #1371924
03/09/13 12:06 AM
03/09/13 12:06 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
as a follow up to this episode, i have to say Josh did in the end look after me well. if it wasn't for our man Josh i doubt wether i'd be a happy man today. if you have to deal with ICH in the future, go straight to Josh, at least we have one man in this company on our side. thank you Josh
Re: is it worth chasing? [Re: rebel] #1371925
03/09/13 03:39 AM
03/09/13 03:39 AM
wentzville mo
1974PW Offline
1974PW  Offline
wentzville mo
wow this is the second account iv seen of a decent person at indy. my good buddy pete is another good guy at ICH
