430 Small Block Mopar build..... #1371199
01/17/13 02:38 PM
01/17/13 02:38 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Auto Enthusiast has a 6 month story ongoing with my 430.
Currently Month 1 is out and Month 2 has just been published.
you can read the online here:
430 Month 1
430 Month 2
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371200
01/17/13 02:50 PM
01/17/13 02:50 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Dave,
What were the grind numbers of both your cams?
I've got a new stroker in the works
WIZE
In Car:
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371201
01/17/13 02:53 PM
01/17/13 02:53 PM
Truck Y'all ! Offline
Looks like an article full of helpful info. Out of curiosity, did you consider using Mopar's small block casting? It has siamese bores and can easily deliver 440 cubes without too much hassle.
Was cost the main factor? I know the block ain't cheap but you might have made up for it by saving on machining expense.
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371202
01/17/13 03:01 PM
01/17/13 03:01 PM
BPE Offline
BPE  Offline
"Long Overhaul" is right.
Rod
Re: 430 Small Block Mopar build..... [Re: Streetwize] #1371203
01/17/13 04:50 PM
01/17/13 04:50 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Dave,
the big cam was ur 258/262, Lift .639/645 w/ 1.5's
the small cam was a comp XR280R
they both made the same torque, no matter what intake, head, or anything else we threw at it - although the RPM range changed significantly.
Re: 430 Small Block Mopar build..... [Re: Truck Y'all !] #1371204
01/17/13 04:51 PM
01/17/13 04:51 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Yes I considered it Jon - I had the X block sitting here collecting dust.
Re: 430 Small Block Mopar build..... [Re: BPE] #1371205
01/17/13 04:52 PM
01/17/13 04:52 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Rod
With a little extra emphasis on the " LONG" part...lol
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371206
01/17/13 05:22 PM
01/17/13 05:22 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Loooking back on the build, I'm thinking about doing something very similar and just trying out the Airwolfs.
I have a 360 block but might try to find a 4.22" max bore Siamese if the right deal comes along.
torque is definately more short block configuration, displacement and then compression related, peak torque is your maximum Volumetric Efficency point, I like to get there as early as feasible to suit the combo (lower RPM is easier on the block) and then rely on the heads and induction to keep it as close to peak torque for as long as possible...it's the best way to make reliable and consistent street strip power IMHO.
This chart is very telling, look at how broad the curve is.....at least 495 lb/ft from 3800 to 6700 rpm. An excellent rule of thumb is if you are at 85-90% of peak torque over a braod RPM range your converter stall flash and shift recovery RPM can pretty much fall anywhere in that range and it won't make too much performance difference, the car is still gonna move. Another advantage for bracket racing is your shift points are not as critical to remain consistent, many of us have seen tracks with slick spots or bumps where we had to short shift to keep from breaking traction. The more "peaky" the torque curve, the more critical the vert has to match up.
While your torque curve is flat your power curve is essentially linear (hp gain per every 100rpm)
Re: 430 Small Block Mopar build..... [Re: Streetwize] #1371207
02/21/13 01:39 PM
02/21/13 01:39 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Month 3 is out - Pre-assembly & Balancing
430 Month 3
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371208
02/21/13 02:52 PM
02/21/13 02:52 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371209
02/21/13 03:08 PM
02/21/13 03:08 PM
Renton Washington
Triple Threat Offline
Renton Washington
Have you considered stepping the camshaft up even more? Seems like there is still room to grow.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 430 Small Block Mopar build..... [Re: Triple Threat] #1371210
02/21/13 03:30 PM
02/21/13 03:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dave do you have any info to get a subscription to that mag ? After mine was switched to Muusclecar Enthuiest when Mopar Enthuiest went under I let that mag run out. But I was thinking about getting it again and now with your story in it I think I might get it again. Is the eng done and in the car Dave as of now ? Thanks , Ron
Re: 430 Small Block Mopar build..... [Re: Triple Threat] #1371211
02/21/13 10:21 PM
02/21/13 10:21 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Yes, but I'm in the middle of a few other things right now - A little more duration would seem to help the numbers IMO
Re: 430 Small Block Mopar build..... [Re: 383man] #1371212
02/21/13 10:23 PM
02/21/13 10:23 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Hey Ron - you can go to this link :
SUBSCRIPTION PAGE
I wish the car was ready, but I have a 68 Cuda that is waiting to get some work done and have this sucker drop in it.
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371213
04/18/13 09:26 PM
04/18/13 09:26 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
They don't list all the info they out in print- such as cfm ratings port volume and such but here is month 4 of 6
Month 4
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371214
07/04/13 11:15 AM
07/04/13 11:15 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Month 5. Was just posted
It's the final assembly process.
Last one coming up. Dyne testing.
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371215
08/22/13 11:29 AM
08/22/13 11:29 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
6th and FINAL month!!!
In the books!
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371216
08/22/13 12:46 PM
08/22/13 12:46 PM
Renton Washington
Renton Washington
Nice, easy read Dave. Now stick that thing in a car already!
-Dustin
Re: 430 Small Block Mopar build..... [Re: Triple Threat] #1371217
01/08/14 11:19 AM
01/08/14 11:19 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Bump in reference to stroke / rod thread.
Re: 430 Small Block Mopar build..... [Re: DJVCuda] #1371218
01/08/14 12:32 PM
01/08/14 12:32 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Nice work
