Re: Rollbars/cages livable on the street?
[Re: hudsonhornet7x]
#1371164
01/17/13 01:59 PM
01/17/13 01:59 PM
RapidRobert
At the very least I'd use a 4 point cage (& likely more) plus subframe connectors. No info on a kit but as you said it'd be about how much jungle jim you're willing to tolerate.
[Re: RapidRobert]
#1371165
01/17/13 02:03 PM
01/17/13 02:03 PM
Posts: 1,541 USA
hudsonhornet7x
USA
THanks, I have installed subframe connectors, torque boxes, inner fender to firewall braces, and a radiator core support brace. i want to stregthen the car as much as I can.
#1371166
01/17/13 02:06 PM
01/17/13 02:06 PM
Posts: 1,151 Cruising!
QuickDodge
Cruising!
I wouldn't want a roll cage on a street car. I've been led to believe that a roll cage should only be used in a car where the driver is wearing a helmet,race car style restraints and protective gear. A typical 3 point seat belt allows a person's body to move around in the car to a degree. In an accident, a person's head could slam into the roll cage causing injuries.
A roll bar located behind the front seats in a car that doesn't have a back seat would probably be ok, but I'm not an expert on this subject.
#1371167
01/17/13 02:07 PM
01/17/13 02:07 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
If you go to Dodge Charger.com,and look at the pictures posted by member Elanmar,and see what his car looked like after a side impact crash,you will want to put a cage in every Mopar from this era. My friend was hit broadside in his 73 Road Runner a few weeks ago and the results were about the same. These cars have zero side impact protection. If my friend was hit on the drivers side he would have died. If he had a passenger with them they would have died. The passengers seat was crushed into the drivers seat. He could stand up with his feet on the ground where the passengers seat used to be! The rocker panel and roof were crushed all the way to the center of the car. I'm currently building a 71 Charger for a daily driver,and i'm looking into a cage and beefing up the rocker panels to improve side impact protection.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#1371168
01/17/13 02:11 PM
01/17/13 02:11 PM
QuickDodge
Cruising!
Hardtop cars, without a post connecting the rocker panels to the roof do NOT fare well in side impacts! (They look good though!)
[Re: chargervert]
#1371173
01/17/13 02:19 PM
01/17/13 02:19 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
My Challenger is a street car with a 25.5 cert cage. Drag Radials, Plated insured & parachute mount slides out & can be placed in the trunk. I have a flip down license plate braket on the rear from a 68' Chevelle for the when the chute bracket is on the car I don't have to remove the license plate.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: dustergirl340]
#1371176
01/17/13 02:35 PM
01/17/13 02:35 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Your head can travel a long distance during an impact, and hitting a metal bar (even padded with foam) without a helmet would hurt. Even a thick head like mine.
I like to sometimes putt around with my three kids in the back seat of the car sometimes. For that reason I will never put a roll bar in my car while it still has a back seat in it. Way too dangerous for whoever is sitting in back IMHO.
I'll run 11.50s with a lap belt before I will do that. At the point someday I run faster than 11.49, a roll bar will go in and the back seat will come out.
[Re: 67Satty]
#1371177
01/17/13 04:38 PM
01/17/13 04:38 PM
chargervert
I was thinking of making the roof hoop so it would fit up tight to the roof just inside the roof structure,then padding it and putting the headliner over it so it is hidden. I was going to pad the roof with insulation to make it seamless. I was going to make the rear seat cross brace removable so it could come out when people are in the rear seat. It could be held in with cleavis pins,and have padded caps with snaps to fit over the recievers when not in use.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
#1371178
01/17/13 05:23 PM
01/17/13 05:23 PM
Posts: 109 OHIO
BUBBAZ572
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
10 PT CAGE IN MY 70 CUDA STREET CAR SWING OUT SIDE BARS NO HALO OR BAR BAR BEHIND THE FRONT SEATS ALSO LEFT OUT THE DASH BAR CAR RUNS 10.0 AND NEVER HAD PROBLEM WITH TECH
[Re: BUBBAZ572]
#1371179
01/17/13 06:37 PM
01/17/13 06:37 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Would it be possible to get a couple pics of your cage? It sounds very interesting.
