How many teeth on hemi #1369749
01/15/13 01:48 AM
01/15/13 01:48 AM
Area 51
Onewickedhemi Offline OP
Area 51
I am going to buy a flywheel for my 528 hemi. I noticed there is different number of teeth on flywheels. Which one do I need to buy?
Re: How many teeth on hemi [Re: Onewickedhemi] #1369750
01/15/13 02:49 AM
01/15/13 02:49 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
172-tooth on the direct-drive-starter 4-speed cars, 143 I think on the A/T cars & later reduction-gear-starter 4-speeds. The direct-drive is not the best starter, slow & spendy.
Re: How many teeth on hemi [Re: topside] #1369751
01/15/13 02:59 AM
01/15/13 02:59 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Re: How many teeth on hemi [Re: thehemikid] #1369752
01/15/13 01:43 PM
01/15/13 01:43 PM
A collage of whims
A collage of whims
Oops, you're right, according to Brewer's; I thought the later 426Hemis used the 11" clutch & flywheel.
BTW, the 130 & 143 flywheels use the same reduction-gear starter.
Re: How many teeth on hemi [Re: Onewickedhemi] #1369753
01/15/13 02:52 PM
01/15/13 02:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The flywheel used is determined by the bellhousing , what bellhousing are you using ?
Re: How many teeth on hemi [Re: topside] #1369754
01/15/13 03:38 PM
01/15/13 03:38 PM
PEI Canada
chromedome426 Offline
PEI Canada
Flywheel needs to be matched with proper bell housing and starter.
66-69 Hemi's came with 172 tooth flywheel, 11" clutch, and a special bell housing for that flywheel and used a direct drive starter.
70-71 Hemi's came with 130 tooth flywheel, 10.5" clutch, and an aluminum bell housing that was suitable for that size flywheel and it used the common reduction gear starter. (same bell housing used on 70-7? big blocks)
You can now also buy a 143 tooth 8 bolt flywheel for the Hemi that uses the 11" clutch and the 68-69 big block cast iron bell housing and the common reduction gear starter. (Note: This set up may have clearance issues with stock manifolds and the starter.) There is an aftermarket direct drive starter available for this set up that clears the manifold. http://www.robbmcperformance.com/products/starter_home.html
The reduction gear starter is the same for manual and automatic transmissions. The different bell housings are made to locate the starter in the correct location for the size of flywheel being used.
Re: How many teeth on hemi [Re: chromedome426] #1369755
01/15/13 06:57 PM
01/15/13 06:57 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The best setup is the 130 tooth flywheel/bellhousing, and if you use a McLeod clutch package (scalloped pressure plate) you get a 10.9" clutch disc/pressure plate that fits the 10.5" flywheel. Allows you to use a conventional gear reduction starter or one of the mini starters, and makes exhaust clearance a lot easier.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: How many teeth on hemi [Re: 64dodge572] #1369756
01/15/13 08:44 PM
01/15/13 08:44 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Wayne
Used this setup in my 528 with brewers 10.5 bell it works good.
Re: How many teeth on hemi [Re: Onewickedhemi] #1369757
01/15/13 10:36 PM
01/15/13 10:36 PM
Area 51
Area 51
OK Men, here is the deal. I have a 528 hemi that we are going to break in on a engine stand. All i need the flywheel for is to start my engine.As you know the starter nose goes into the bell housing. I have a steel after market bell housing. I bought a starter from summit racing. looking on ebay i noticed there are different number teeth. I called mancini racing and he told me 143. once the engine is broken in i am putting in a 727 transmission. What do you think?
Re: How many teeth on hemi [Re: Onewickedhemi] #1369758
01/15/13 11:38 PM
01/15/13 11:38 PM
Area 51
Area 51
I will not put a clutch and pressure plate on the flywheel. All I need the flywheel for is to turn the engine to start it on engine stand.
Re: How many teeth on hemi [Re: Onewickedhemi] #1369759
01/16/13 12:43 AM
01/16/13 12:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what are you using for exhaust off the heads ? best bet would be a 130 tooth wheel as the aftermarket steel bellhousing will work with either the 130 or the 143 , these are sold in both 6 bolt and 8 bolt , get the right one .
Re: How many teeth on hemi [Re: Onewickedhemi] #1369760
01/16/13 12:52 AM
01/16/13 12:52 AM
Area 51
Area 51
I am using the stock exhaust manifolds. Is there a problem with that?
Re: How many teeth on hemi [Re: Onewickedhemi] #1369761
01/16/13 12:59 AM
01/16/13 12:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There will be if you get a 143 tooth wheel , get the 130 .
Re: How many teeth on hemi [Re: Onewickedhemi] #1369762
01/16/13 04:10 PM
01/16/13 04:10 PM
Area 51
Area 51
I will get a 130 tooth, question that I would like to know is what problems will I have if I us a 143 tooth?
Re: How many teeth on hemi [Re: Onewickedhemi] #1369763
01/16/13 04:20 PM
01/16/13 04:20 PM
I used all three sizes of flywheels on my 1970 Hemi Cuda with two different scatter sheilds when I raced it in NHRA stock, the smaller diameter and lighter flywheels work better on the small nine inch tires we had to run, no problems running any of them with headers in the car, the starters where hard to change with the headers Make sure your bellhousing is compatable with the starter and flywheel size It(flywheel size) does make a difference on the stock type bellhousings, not so on the scatter sheilds, except for the early Ansen scatter sheilds
Re: How many teeth on hemi [Re: Onewickedhemi] #1369764
01/16/13 04:59 PM
01/16/13 04:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The starter and the left exhaust manifold may want to share the same space, it was mentioned in a post above.
Re: How many teeth on hemi [Re: JohnRR] #1369765
01/16/13 07:42 PM
01/16/13 07:42 PM
California
mickm Offline
mickm  Offline
California
hope this isn't hijacking the post, but i had the 11" setup and went to the 10.5" setup, which i believe in this case is really the 10.95".
i went from the 142 to the 130 tooth flywheel. i have a mini-starter on there now.
am i going to need a different starter?
Re: How many teeth on hemi [Re: mickm] #1369766
01/16/13 08:43 PM
01/16/13 08:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Headers or manifolds ?
Re: How many teeth on hemi [Re: JohnRR] #1369767
01/16/13 09:14 PM
01/16/13 09:14 PM
California
mickm Offline
mickm  Offline
California
headers.
Re: How many teeth on hemi [Re: mickm] #1369768
01/17/13 09:05 AM
01/17/13 09:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you shouldn't have an issues , mini and a 130 should work fine . it's manifolds where things get tight.
headers.
