Can I paint over the original paint? Pro painters help! #136942
10/15/08 04:52 PM
10/15/08 04:52 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Looking to repaint the Demon (pic attached). This car is wearing it's original paint but I am going with a color change to Sassy Grass. Can I just do spot body work and then scuff/prime/paint over the existing paint? If so, is it really that much of a time saver or should I just sand it down to bare metal? One twist, the quarters have had Pam cooking spray and WD-40 in them to help with rubber from burn outs.
Not looking for a perfect car but a really nice daily driver with paint that looks as good as a new car.
Re: Can I paint over the original paint? Pro painters help! [Re: VITC_GTX] #136943
10/15/08 04:58 PM
10/15/08 04:58 PM
Kirkland, Washington
Pacnorthcuda Offline
The short answer is yes, you can, but there is a risk of certain types of paint failures (lifting/checking etc) in doing so. Keep in mind that paint is 35+ years old.
But you wouldn't be the first to scuff & squirt a job like that.
Re: Can I paint over the original paint? Pro painters help! [Re: Pacnorthcuda] #136944
10/15/08 05:07 PM
10/15/08 05:07 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Are these problems something I would see after spraying primer and waiting a few weeks or could they show up after color is squirted (months later)?
Re: Can I paint over the original paint? Pro painters help! [Re: VITC_GTX] #136945
10/15/08 05:23 PM
10/15/08 05:23 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
If it has one layer of factory paint, and it isn't cracking, then shoot it.........it will be fine. Multiple layers, no............you will have to take it down. Chrysler paint held up better than GM from my experience, prime it with a good urethane primer, and it should hold up.
Re: Can I paint over the original paint? Pro painters help! [Re: VITC_GTX] #136946
10/15/08 05:35 PM
10/15/08 05:35 PM
Certainly a problem could show up later, but thats true if you take it to bare metal too.
IF the paint's in really good shape (no heavy oxidation, chalking, checking, craking, pealing etc.) and you degrease really well (BEFORE ANY sanding scuffing) you might be fine. I would sand/scuff REALLY well--leave NOTHING glossy that will be painted. As you sand you will have a pretty good idea of the strength of the existing paint--if it flies off as soon as it see's sandpaper thats not good!
Its a good way to a fast cheap paint job (and thats OK) but its not the best way--I think you know that.
Re: Can I paint over the original paint? Pro painters help! [Re: VITC_GTX] #136947
10/15/08 07:17 PM
10/15/08 07:17 PM
Columbus Ga
reflections7 Offline
Columbus Ga
If you are spraying urethane ie base clear over the old paint then use a epoxy mixed as a sealer before you spray the color coat. You can go ahead and do your body work and prime over the original paint but I would reccomend a sealer. BTW you dont need that much sealer just a light coat usually a qt mixed with hardner and reduced is about 2 qts sprayable plenty to do the car so dont let them sell you a gallon.
Re: Can I paint over the original paint? Pro painters help! [Re: VITC_GTX] #136948
10/15/08 08:27 PM
10/15/08 08:27 PM
Maryland
reno340 Offline
reno340  Offline
Maryland
Why would you want to paint an original paint car? Plus,I think that color adds character to the car. Seen too many sassy grass green A-Bodies I guess. Just remember this, a car only has original paint once! Would be a shame.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Can I paint over the original paint? Pro painters help! [Re: reno340] #136949
10/15/08 09:54 PM
10/15/08 09:54 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I agree that original paint can be a neat feature but I just can't go with the brown. I'm sure there are more Sassy Grass Demons now than they actually made in '71 & '72, but I know they made one too many brown ones
Re: Can I paint over the original paint? Pro painters h [Re: VITC_GTX] #136950
10/16/08 02:23 AM
10/16/08 02:23 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Cool looking Demon.
I agree 2 many brown Demons.
I am changing mine to silver
with black stripes.
Re: Can I paint over the original paint? Pro painters help! [Re: reflections7] #136951
10/16/08 07:28 AM
10/16/08 07:28 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
