Can I paint over the original paint? Pro painters help!
#136942
10/15/08 04:52 PM
10/15/08 04:52 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
Looking to repaint the Demon (pic attached). This car is wearing it's original paint but I am going with a color change to Sassy Grass. Can I just do spot body work and then scuff/prime/paint over the existing paint? If so, is it really that much of a time saver or should I just sand it down to bare metal? One twist, the quarters have had Pam cooking spray and WD-40 in them to help with rubber from burn outs.
Not looking for a perfect car but a really nice daily driver with paint that looks as good as a new car.
Re: Can I paint over the original paint? Pro painters help!
[Re: VITC_GTX]
#136946
10/15/08 05:35 PM
10/15/08 05:35 PM
Posts: 21,827 Kirkland, Washington
Pacnorthcuda
Certainly a problem could show up later, but thats true if you take it to bare metal too. IF the paint's in really good shape (no heavy oxidation, chalking, checking, craking, pealing etc.) and you degrease really well (BEFORE ANY sanding scuffing) you might be fine. I would sand/scuff REALLY well--leave NOTHING glossy that will be painted. As you sand you will have a pretty good idea of the strength of the existing paint--if it flies off as soon as it see's sandpaper thats not good! Its a good way to a fast cheap paint job (and thats OK) but its not the best way--I think you know that.
[Re: VITC_GTX]
#136948
10/15/08 08:27 PM
10/15/08 08:27 PM
Posts: 386 Maryland
reno340
Maryland
Why would you want to paint an original paint car? Plus,I think that color adds character to the car. Seen too many sassy grass green A-Bodies I guess. Just remember this, a car only has original paint once! Would be a shame.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
[Re: reno340]
#136949
10/15/08 09:54 PM
10/15/08 09:54 PM
VITC_GTX
I agree that original paint can be a neat feature but I just can't go with the brown. I'm sure there are more Sassy Grass Demons now than they actually made in '71 & '72, but I know they made one too many brown ones
[Re: reflections7]
#136951
10/16/08 07:28 AM
10/16/08 07:28 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
If you are spraying urethane ie base clear over the old paint then use a epoxy mixed as a sealer before you spray the color coat. You can go ahead and do your body work and prime over the original paint but I would reccomend a sealer. BTW you dont need that much sealer just a light coat usually a qt mixed with hardner and reduced is about 2 qts sprayable plenty to do the car so dont let them sell you a gallon.
