new Holley 6 bbl carbs...wrong float bowl screws?? #1368861
01/13/13 11:52 AM
01/13/13 11:52 AM
Detroit, MI
RPM Motorsports Offline OP
Detroit, MI
I bought some of the newer Holley "OEM restoration 6 pack carbs", but they have hex head float bowl screws...where can I get the correct screws? I am far from an expert on super 100% correct concourse stuff, but now I'm wondering what else is not so "OEM original" about these. Any tips or info would be appreciated. Thanks in advance!!
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: RPM Motorsports] #1368862
01/13/13 12:02 PM
01/13/13 12:02 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
any old holley would work for the bowl screws...theyre correct in fit and function, prob not to concerned with hardware, you cant see the bowl screws with the air cleaner on anyways
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: RPM Motorsports] #1368863
01/13/13 12:25 PM
01/13/13 12:25 PM
MD
floyd Offline
floyd  Offline
MD
They're available from Mopar vendors. Did a quick google:
http://www.rosevillemoparts.com/product_...cts_id/7297?SID
Not sure what else is different about the new carbs but it probably minimal unless you're doing a concours-type resto
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: floyd] #1368864
01/13/13 12:36 PM
01/13/13 12:36 PM
Detroit, MI
Detroit, MI
Nope...no concourse level resto going on here. But it is odd that Holley hypes them up to be so accurate. They even stamped original MoPar part numbers and date codes on them. Then, they use the wrong float bowl screws?? That sticks out like a sore thumb even on a casual back yard resto like I am doing!!
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: RPM Motorsports] #1368865
01/13/13 12:47 PM
01/13/13 12:47 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
got these .
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: gtx6970] #1368866
01/13/13 12:50 PM
01/13/13 12:50 PM
It's a dry heat
It's a dry heat
If you want those, might as well get the correct carb to intake bolts
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: gtx6970] #1368867
01/13/13 01:00 PM
01/13/13 01:00 PM
Detroit, MI
Detroit, MI
There is 2 different length screws for the float bowls in those kits??
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: RPM Motorsports] #1368868
01/13/13 01:02 PM
01/13/13 01:02 PM
It's a dry heat
It's a dry heat
correct, center carb takes a slightly longer one.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: RPM Motorsports] #1368869
01/13/13 03:16 PM
01/13/13 03:16 PM
Shoreline, Washington
72roadrunnergtx Offline
The stamped List & Chrysler part numbers on the reissues six-pack carbs represent original design specifications for their original applications only. They will contain minor Holley overall production changes that have occurred in the years since the original carbs went out of production as long as they don’t alter the design specs as they pertain to functionality. Holley went to hex head fuel bowl screws many years ago. More than likely to improve the process of setting even fuel bowl screw torque specifications on a mounted carb. It was a pain in the rear with slotted screw heads. Mine also had contained the newer gasket materials and the later blow-out resistant power valve. Date code should be reflective of the actual production date of the reissue. Carb pictured below was purchased new around ’07. Note the Torx headed screw securing the bowl vent lever rod, pretty sure that was a Phillips head screw originally.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: gtx6970] #1368870
01/13/13 03:17 PM
01/13/13 03:17 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
i have always had problems torquing the screws to the correct torque. I was enthralled when Holley went to hex head capscrews.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: 6PakBee] #1368871
01/13/13 04:25 PM
01/13/13 04:25 PM
MD
floyd Offline
floyd  Offline
MD
Didn't the original carbs has different part numbers for the front and rear carbs? I believe the new carbs have only one part number.
I should have known you had them Bill!
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: floyd] #1368872
01/13/13 04:45 PM
01/13/13 04:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct on all accounts. These are the differences that restoration minded owners need to be aware of when deciding on which way to go, buy new carbs or restore what they have, there are a bunch of small differences between vintage Holley's vs new when it comes to details, screws, misc. hardware, the Holley script on the bowls, plating and dip color, all kinds of stuff.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: floyd] #1368873
01/13/13 04:58 PM
01/13/13 04:58 PM
"Didn't the original carbs has different part numbers for the front and rear carbs? I believe the new carbs have only one part number."
The available reissued list numbers are basically a consolidation of all the original numbers produced back then. Jetting/metering plates were staggered front to rear on most factory installs, requiring deferent list numbers front or rear, otherwise the same carbs. Wouldn’t make economic sense for Holley to reproduce every original variation/list numbered carb.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: 72roadrunnergtx] #1368874
01/15/13 12:31 AM
01/15/13 12:31 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
As for the bowl vent screw I've seen both Phillips and slotted Fillister head on original carbs.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: RPM Motorsports] #1368875
04/01/13 08:42 PM
04/01/13 08:42 PM
Right Coast
Fabman Offline
Fabman  Offline
Right Coast
I dont mean to steal this thread...BUT...I am looking for a replacement fuel bowl for the rear carb on my 6 pack set up...Its a 340 T/A - Carb number is a R4970A. The one thats on the car now is wrong...It has the accelerator pump holes epoxied shut....and now its starting to drip......
Thanks !
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: Fabman] #1368876
04/01/13 10:41 PM
04/01/13 10:41 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thanks !
Carb number makes no difference,front and rear big block and small block are all the same.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: 62maxwgn] #1368877
04/02/13 08:18 AM
04/02/13 08:18 AM
Right Coast
Fabman Offline
Fabman  Offline
Right Coast
Thanks !
Great ! Good info....now...anyone know where I can get one???
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: 62maxwgn] #1368878
04/02/13 11:48 AM
04/02/13 11:48 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
For comparison, here's the ID from an original carb. Notice that there is no 7 digit Chrysler part number.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: Fabman] #1368879
04/02/13 12:14 PM
04/02/13 12:14 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Thanks !
Did you try Holley ? last time I checked they sell parts also.
Re: new Holley 6 bbl carbs...wrong float bowl screws?? [Re: JohnRR] #1368880
04/02/13 12:34 PM
04/02/13 12:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thanks !
John,only thing wrong with Holley is the price !! Out of these three sets,there were five bad bowl's,three had stripped needle /seat threads which I fixed,the other were Chevy bowls which I replaced,the two I bought from Chicago Corvette cost me less than $60. for both .
