Page 1 of 3 1 2 3
champion vs. NGK sparkplugs #1368792
01/13/13 10:46 AM
01/13/13 10:46 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Any difference in performance between the 2 sparkplug manufacturers?
Champion szparkplugs are nearly 3 times the price.
I was looking to buy a set of Champion C59CX
Re: champion vs. NGK sparkplugs [Re: Sammy] #1368793
01/13/13 10:53 AM
01/13/13 10:53 AM
ill
dennismopar73 Offline
ill
I have run all kinds of plugs Autolite, N G K , Chapions, Denso, Pulsar, etc.
Some will say they have seen some performance gains, ,, I haven't so long as it the same plug heat range.
Normaly that is the issue, plus contamination thru the combustion mix that will be the leading cause of issues with plugs,
So guys will change plugs and heat ranges to compensate for such issues.
Besides be amazed as to who makes most plugs anyways!
Re: champion vs. NGK sparkplugs [Re: dennismopar73] #1368794
01/13/13 12:23 PM
01/13/13 12:23 PM
Az
Crizila Offline
Crizila  Offline
Az
but I like NGK. I think their manufacturing quality control is better than Champion and others. Ground straps are always positioned the same over the electrodes and gaps are always consistant right out of the box.
Fastest 300
Re: champion vs. NGK sparkplugs [Re: Sammy] #1368795
01/13/13 12:32 PM
01/13/13 12:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only difference is the cut back strap vs the
standard strap... a few HP has been seen running
the cut back strap on dynos
EDIT
I changed over to Autolite race plugs with the cut
back strap
Re: champion vs. NGK sparkplugs [Re: MR_P_BODY] #1368796
01/13/13 12:58 PM
01/13/13 12:58 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I worked in many tune up shops. Changed a LOT of plugs...
There are some that swear by Champion, and they are stock on Mopars for many years.
I dislike them. They had poor QA and tended to foul easier than Autolite and NGK.
The porcelain was more brittle and would break easier too.
Re: champion vs. NGK sparkplugs [Re: RodStRace] #1368797
01/13/13 01:07 PM
01/13/13 01:07 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Autolite
5.53 @ 125 1/8th on the launch control..more left in her!
Re: champion vs. NGK sparkplugs [Re: Eric] #1368798
01/13/13 01:17 PM
01/13/13 01:17 PM
tboomer Offline
tboomer  Offline
Used Autolite
Fixed it for ya,Eric!!!
Re: champion vs. NGK sparkplugs [Re: tboomer] #1368799
01/13/13 01:32 PM
01/13/13 01:32 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Used Autolite
Perfect!!!!
Russ
Re: champion vs. NGK sparkplugs [Re: max_maniac] #1368800
01/13/13 01:47 PM
01/13/13 01:47 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i prefer autolite
Re: champion vs. NGK sparkplugs [Re: max_maniac] #1368801
01/13/13 01:50 PM
01/13/13 01:50 PM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
If it's the right plug for the application and the car is tuned right. It dosent matted what you put in it. They only know to spark. I always used Champion in my braket cars because everybody else said they were junk. I was winning 15-20 braket races a year and using the same plugs sometimes for two seasons. While my friends and competators sometimes changed theirs weekly.
Re: champion vs. NGK sparkplugs [Re: Sammy] #1368802
01/13/13 02:27 PM
01/13/13 02:27 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I run the cheap Autolite plugs. I found no difference between the plugs for performance or longevity - and my heap EATS plugs. So I just buy the cheap ones. I do however have to purposely screw-up the threads to keep the little connector "nibs" from coming loose.
Autolite 3923s FTW!
Re: champion vs. NGK sparkplugs [Re: Duner] #1368803
01/13/13 02:56 PM
01/13/13 02:56 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I prefer NGK or Autolite.
Re: champion vs. NGK sparkplugs [Re: Sammy] #1368804
01/13/13 03:17 PM
01/13/13 03:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
Buy a set of NGK, Autolites and Champion and try them one at a time and then decide. I use different brands and type and heat range for my motors. Tell us a little about your motor, compression ratio, iron or aluminum head and type fo fuel ad the planned usage, IE race only, street and and strip, street only.
Re: champion vs. NGK sparkplugs [Re: Cab_Burge] #1368805
01/13/13 03:30 PM
01/13/13 03:30 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Used to use Champions until they discontinued the J-11Y. I've been using NGK's and seem to do the best in my junk.Dave
Re: champion vs. NGK sparkplugs [Re: MR_P_BODY] #1368806
01/13/13 03:41 PM
01/13/13 03:41 PM
Az
Crizila Offline
Crizila  Offline
Az
EDIT
back strap
NGK race plugs ( non-resister ) come out of the box with the ground straps cut back.
Fastest 300
Re: champion vs. NGK sparkplugs [Re: Sammy] #1368807
01/13/13 03:46 PM
01/13/13 03:46 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
NGK's in a street 440(subjected to a lot of heat, idle time, and fluctuating humidity)since day one(20+years)...
Re: champion vs. NGK sparkplugs [Re: RSNOMO] #1368808
01/13/13 03:53 PM
01/13/13 03:53 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I've been using NGK only because I was having issues with the Champions fouling out.
I'm surprised to see a few Autolite fans. I'm used to seeing most mopar guys swear at them. They do tend to live a bit longer though.
Re: champion vs. NGK sparkplugs [Re: MPerry] #1368809
01/13/13 04:33 PM
01/13/13 04:33 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
NGK or Autolite.
On dirt cars, Ive seen Champions blow the porcelain out on a few occasions. Only seen it happen to Champions.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: champion vs. NGK sparkplugs [Re: Von] #1368810
01/13/13 05:50 PM
01/13/13 05:50 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
NGK or Autolite.
Same deal on marine engines,
Re: champion vs. NGK sparkplugs [Re: emarine01] #1368811
01/13/13 06:15 PM
01/13/13 06:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I have seen champion's do the same thing on a drag car. I use NGK's
Page 1 of 3 1 2 3
