Re: champion vs. NGK sparkplugs
[Re: Sammy]
#1368793
01/13/13 10:53 AM
01/13/13 10:53 AM
Posts: 2,177 ill
dennismopar73
ill
I have run all kinds of plugs Autolite, N G K , Chapions, Denso, Pulsar, etc. Some will say they have seen some performance gains, ,, I haven't so long as it the same plug heat range. Normaly that is the issue, plus contamination thru the combustion mix that will be the leading cause of issues with plugs, So guys will change plugs and heat ranges to compensate for such issues. Besides be amazed as to who makes most plugs anyways!
[Re: dennismopar73]
#1368794
01/13/13 12:23 PM
01/13/13 12:23 PM
Posts: 7,506 Az
Crizila
Az
but I like NGK. I think their manufacturing quality control is better than Champion and others. Ground straps are always positioned the same over the electrodes and gaps are always consistant right out of the box.
Fastest 300
[Re: Sammy]
#1368795
01/13/13 12:32 PM
01/13/13 12:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The only difference is the cut back strap vs the standard strap... a few HP has been seen running the cut back strap on dynos EDIT I changed over to Autolite race plugs with the cut back strap
[Re: MR_P_BODY]
#1368796
01/13/13 12:58 PM
01/13/13 12:58 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I worked in many tune up shops. Changed a LOT of plugs... There are some that swear by Champion, and they are stock on Mopars for many years. I dislike them. They had poor QA and tended to foul easier than Autolite and NGK. The porcelain was more brittle and would break easier too.
[Re: tboomer]
#1368799
01/13/13 01:32 PM
01/13/13 01:32 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Used Autolite
Fixed it for ya,Eric!!!
Perfect!!!!
Russ
[Re: Sammy]
#1368804
01/13/13 03:17 PM
01/13/13 03:17 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Buy a set of NGK, Autolites and Champion and try them one at a time and then decide. I use different brands and type and heat range for my motors. Tell us a little about your motor, compression ratio, iron or aluminum head and type fo fuel ad the planned usage, IE race only, street and and strip, street only.
[Re: MPerry]
#1368809
01/13/13 04:33 PM
01/13/13 04:33 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
NGK or Autolite.
On dirt cars, Ive seen Champions blow the porcelain out on a few occasions. Only seen it happen to Champions.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1368810
01/13/13 05:50 PM
01/13/13 05:50 PM
Posts: 3,695 nc
emarine01
nc
NGK or Autolite.
Same deal on marine engines,
