Ring End Gap ??? #1368683
01/12/13 11:30 PM
01/12/13 11:30 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
What are you guy's using for ring end gap with these parts. This is being used in a street brawler. 440 Source 500 inch 440 stroker with the 5095 .055 over piston and their supplied ring CR9190-130 that are from Total Seal.
I see on Total Seals web site, they call for more ring end gap on the second ring. The paper work that came with the pistons figures out to have the top ring at .020 and the second ring at .016.
Who's correct??
Dan
Re: Ring End Gap ??? [Re: mopar4ya] #1368684
01/12/13 11:44 PM
01/12/13 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Who's correct??
Dan
The paper work that came with the rings is OLD(20+
years)... the top ring is right with the spec they
call out for .004+ per inch of bore but the second
ring MOST are making that larger than the first by
.005(as in if the top is .022 make the second .027)
Re: Ring End Gap ??? [Re: mopar4ya] #1368685
01/12/13 11:47 PM
01/12/13 11:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine are .018 top and .027 bottom iirc on a 4.377 bore...
Re: Ring End Gap ??? [Re: mopar4ya] #1368686
01/12/13 11:58 PM
01/12/13 11:58 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
testing has shown opening the second ring gap improves the sealing of the top ring as it bleeds off inter-ring pressure which helps keep the top ring seated.
Re: Ring End Gap ??? [Re: mopar4ya] #1368687
01/13/13 12:44 AM
01/13/13 12:44 AM
On a pump gas iron block 4.375 bore aluminum headed motor with 10.5 to 1 (with forged aluminum pistons, not Hyperutetics SP?)or lower I set the top gap at .022 or wider and the second ring at .026 or wider Wider is better, especially on pump gas street motor, on any motor that will build heat for substained periods of time in the combustion chamber
Re: Ring End Gap ??? [Re: Cab_Burge] #1368688
01/13/13 10:41 AM
01/13/13 10:41 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
This is a iron head engine, no power aid's. Looks like .022 and .027 should be good. Any reason to open them up any more??
Dan
Re: Ring End Gap ??? [Re: mopar4ya] #1368689
01/13/13 10:25 PM
01/13/13 10:25 PM
Dan
None at all, those will work good Keep them square and make those readings with a tight fit Not loose, take your time on the last .002 Buy a good small sharpening stone to smooth the edges of the filed rings, top and bottom, front and back
Re: Ring End Gap ??? [Re: Cab_Burge] #1368690
01/14/13 06:31 AM
01/14/13 06:31 AM
sweden
sshemi Offline
sshemi  Offline
sweden
My experience is that it doesnt make any difference if you go a little more than recomended.
I think speed pro rec 0.004 per inch of bore on top and 0.0045 second.
Re: Ring End Gap ??? [Re: sshemi] #1368691
01/14/13 09:34 PM
01/14/13 09:34 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thanks! have everything fitted and ready to drop down the holes.
Dan
