Ring End Gap ???
#1368683
01/12/13 11:30 PM
01/12/13 11:30 PM
Posts: 2,655 western PA
mopar4ya
western PA
What are you guy's using for ring end gap with these parts. This is being used in a street brawler. 440 Source 500 inch 440 stroker with the 5095 .055 over piston and their supplied ring CR9190-130 that are from Total Seal. I see on Total Seals web site, they call for more ring end gap on the second ring. The paper work that came with the pistons figures out to have the top ring at .020 and the second ring at .016. Who's correct?? Thanks Dan
Re: Ring End Gap ???
[Re: mopar4ya]
#1368684
01/12/13 11:44 PM
01/12/13 11:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Who's correct??
Thanks Dan
The paper work that came with the rings is OLD(20+ years)... the top ring is right with the spec they call out for .004+ per inch of bore but the second ring MOST are making that larger than the first by .005(as in if the top is .022 make the second .027)
[Re: mopar4ya]
#1368685
01/12/13 11:47 PM
01/12/13 11:47 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Mine are .018 top and .027 bottom iirc on a 4.377 bore...
[Re: Cab_Burge]
#1368688
01/13/13 10:41 AM
01/13/13 10:41 AM
mopar4ya
western PA
This is a iron head engine, no power aid's. Looks like .022 and .027 should be good. Any reason to open them up any more?? Thanks Dan
