front seat recline on 69 charger? #1367553
01/10/13 05:49 PM
01/10/13 05:49 PM
toronto canada
69chargeryeehaa Offline OP
toronto canada
so at 6.2' the front seats are driving me nuts. And there is no recline setting so i'm forced to sit upright like i'm in the 60's
any ideas to recline the seat back?
my thoughts so far were to add a block under the front seat bolts, or cut the seat back and weld to a better more comfortable setting...
ideas?
Re: front seat recline on 69 charger? [Re: 69chargeryeehaa] #1367554
01/10/13 06:26 PM
01/10/13 06:26 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Drop the $500 for a 6 way seat adjuster, they are available on the web. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: front seat recline on 69 charger? [Re: astjp2] #1367555
01/10/13 07:00 PM
01/10/13 07:00 PM
toronto canada
toronto canada
link?
Any other ideas on something easy to just add a few inches of recline?
Re: front seat recline on 69 charger? [Re: 69chargeryeehaa] #1367556
01/11/13 06:05 AM
01/11/13 06:05 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
link?
http://www.dodgecharger.com/forum/index.php?topic=77184.0
Google is your friend
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: front seat recline on 69 charger? [Re: astjp2] #1367557
01/11/13 12:43 PM
01/11/13 12:43 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Look on eBay and CL...I found 2003 BMW M3 seats in black leather for my 70 Dart at a whopping $250 pricetag. Made brackets for the seat tracks and popped em into the factory holes but really moved the seat back 4"...I am 6'5 and I despise the factory seating arrangements....
I sit comfortable even now with custom cloth seats (velour) from a Porsche 944 Turbo...Lumbar support, airbag technology...I think they were out of an early 90s model. Suits me fine
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: front seat recline on 69 charger? [Re: Pyper70] #1367558
01/11/13 01:21 PM
01/11/13 01:21 PM
toronto canada
toronto canada
i would prefer to make something either adjustable or actually cutting the rear support arms and welding them back at a better angle, and would prefer to use the original seats without adding power 6way, would like to keep it factory as my car came.
Re: front seat recline on 69 charger? [Re: 69chargeryeehaa] #1367559
01/11/13 03:16 PM
01/11/13 03:16 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If you start cutting then its not original, right? So why not get something that is comfortable and fits you well. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: front seat recline on 69 charger? [Re: 69chargeryeehaa] #1367560
01/11/13 03:36 PM
01/11/13 03:36 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
If it makes a difference, the factory 6-way is manual, not power.
Re: front seat recline on 69 charger? [Re: 318 Stroker] #1367561
01/11/13 04:21 PM
01/11/13 04:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
True but the 6way base does raise the seat higher, if he is having an issue now this may not make it better. Also it doesn't recline the seat , it tips the entire seat back , may or may not be what he wants and $500 to TEST it out is a lot ...
Re: front seat recline on 69 charger? [Re: JohnRR] #1367562
01/11/13 04:40 PM
01/11/13 04:40 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
But he could tip the seat back with a simple block of wood.
Cost virtually nothing, totally reversible, and doesn't raise the seat like a 6-way.
Re: front seat recline on 69 charger? [Re: autoxcuda] #1367563
01/11/13 05:33 PM
01/11/13 05:33 PM
toronto canada
toronto canada
ya and higher would be worse, my head already just barley clears the headliner. I'm not worried about modifying the seat, never planning on selling the car, is just has to fit me!!!
i was thinking about spacing the front of the seat higher, so that may be the best option for now until i come up with something better.
Re: front seat recline on 69 charger? [Re: 69chargeryeehaa] #1367564
01/11/13 07:33 PM
01/11/13 07:33 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Remove the back shims and add them to the front. Worked for me.
