What sort of grease to use on drum backing plates? #136729
10/15/08 02:35 AM
10/15/08 02:35 AM
Zebulon
Stationwagonguy Offline OP
A Closet Buick Man
A Closet Buick Man
Zebulon
What sort of grease are you supposed to use on the little "pads" on the rear drum backing plates that the brake shoes ride on? I forgot. uch:
[image][/image] Bob SWG '68 Chrysler Town & Country, 'Katy Jo' '70 Chrysler 300 2-door '78 Impala 2-door
Re: What sort of grease to use on drum backing plates? [Re: Stationwagonguy] #136730
10/15/08 02:47 AM
10/15/08 02:47 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I actually did Lubriplate no sieze on my front 9"ers on the Duster
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: What sort of grease to use on drum backing plates? [Re: Stationwagonguy] #136731
10/15/08 03:53 AM
10/15/08 03:53 AM
places
79powerwagon Offline
places
Brake grease?
I use the silicone based stuff myself (won't melt under high heat situations).
Re: What sort of grease to use on drum backing plates? [Re: Stationwagonguy] #136732
10/16/08 10:23 AM
10/16/08 10:23 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I use the silicon based caliper grease as well, but only after I deburr and "polish" the contact pads with a dremel and a wire wheel. This allows for smoother movement of the shoes.
I've had backing plates that had wear marks which interfeared with the smooth movement of the shoes. I had to carefully remove the rough edges to restore the contact pads prior to smearing the thinest layer of the grease on the contact areas.
Don't use too much grease either of you will contaminate the brake pads.
