holley 750 vac issues #1366121
01/07/13 10:51 PM
01/07/13 10:51 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Ive never really dinked around with vacuum secondary carbs much. I just went through one for my 63 413 4 speed. It idles and starts good but has a cruise stumble. When cruising steady throttle at 2000 rpms and I try excellerating slowly it cuts out. If I mash it it goes. Its that mid rpm cruising range that seems to be the problem..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: holley 750 vac issues [Re: HOTMOPR] #1366122
01/07/13 10:57 PM
01/07/13 10:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like the pump shot is late... make sure as soon
as the throttle moves its getting the pump shot
Re: holley 750 vac issues [Re: MR_P_BODY] #1366123
01/07/13 11:35 PM
01/07/13 11:35 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
I have the pump arm gap at .015
Re: holley 750 vac issues [Re: HOTMOPR] #1366124
01/07/13 11:39 PM
01/07/13 11:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Is it a Holley - 3310? A slight stumble while cruising with light throttle can be caused by some junk in the carb causing a lean condition in the transition or possibly main circuit. That has been my experience more than once on Holleys.
Re: holley 750 vac issues [Re: BSB67] #1366125
01/07/13 11:51 PM
01/07/13 11:51 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
yes its a 3310. I had it all apart and it was cleaned and reassembled.
Re: holley 750 vac issues [Re: HOTMOPR] #1366126
01/08/13 12:10 AM
01/08/13 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you good getting up to cruise and then it wont
take any pedal... could be your secondary is opening
to easy... put a slightly stiffer spring in it
Re: holley 750 vac issues [Re: MR_P_BODY] #1366127
01/08/13 12:57 AM
01/08/13 12:57 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
It seems to stumble at lower rpms. Unfortunatly The weather has been crappy and I havent had much chance to drive it since I got it running. It runs great in the shop. Idle and throttle response is great but under load its a different story.
Re: holley 750 vac issues [Re: HOTMOPR] #1366128
01/08/13 01:03 AM
01/08/13 01:03 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I had that problem. I went up to the next size squirter and adjusted the pump screw to let it squirt sooner..
I am truckless..
Re: holley 750 vac issues [Re: 340SHORTY] #1366129
01/08/13 01:11 AM
01/08/13 01:11 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
I thought about trying a bigger squirter. I guess I'll try closing up that pump gap also since Mr p mentioned that too. I know bigger squirters helped my starting line bog on my 980 double pumper..
Re: holley 750 vac issues [Re: HOTMOPR] #1366130
01/08/13 03:43 AM
01/08/13 03:43 AM
USA
540DUSTER Offline
540DUSTER  Offline
USA
the gap is measured with the throttle open all the way,not at idle.
Re: holley 750 vac issues [Re: MR_P_BODY] #1366131
01/08/13 08:49 AM
01/08/13 08:49 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
On Mopar's a vacuum carb should never be used...But it also sounds like you squirter shot is a little late or small or both.
Re: holley 750 vac issues [Re: Dragula] #1366132
01/08/13 02:37 PM
01/08/13 02:37 PM
dogdays Offline
dogdays  Offline
There are also about 10 different accelerator pump cams to try.
R.
Re: holley 750 vac issues [Re: HOTMOPR] #1366133
01/08/13 04:39 PM
01/08/13 04:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also make sure you have enough timing
Re: holley 750 vac issues [Re: 540DUSTER] #1366134
01/08/13 05:42 PM
01/08/13 05:42 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
this
Re: holley 750 vac issues [Re: Dragula] #1366135
01/08/13 05:46 PM
01/08/13 05:46 PM
Guitar Jones Offline
Uh why? I've used vacuum sec carbs for years on my race car to slow it down. A screw and a lock nut on the vacuum pod cap stops the opening very well.
Re: holley 750 vac issues [Re: Guitar Jones] #1366136
01/09/13 12:15 AM
01/09/13 12:15 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
There are a whole range of different springs that are color-coded to vary the opening timing and duration of the the secondaries. They have a dab of paint on the small end of the spring. IIRC, the gold spring was the lightest one that was used at the strip. You might check your carb gaskets and hoses to make sure you don't have an air leak there. I run a 950HP carb that has a vac-sec pot on it, silver spring. It has been 10.24 at 128 MPH on my Duster.
Re: holley 750 vac issues [Re: HOTMOPR] #1366137
01/21/13 11:33 PM
01/21/13 11:33 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
PUNTING!! I give up on the 750! I went back to my 850 dbl pumper. Problem I am having with this carb is I cant get it to idle down. I welded up the drilled primary throttle blades. The secondaries are not drilled and it doesnt have the secondary idle adjustment. Right now the best I can get it is 1100 rpms. Which might be fine in a auto with a bigger cam but the 4 speed likes about 800. Any ideas why it wont idle down. No cables were hooked up so nothing is binding. blades appear to be closed when looking down inside.. I also sprayed carb cleaner around it and no vacuum leaks.. Any Ideas?
Re: holley 750 vac issues [Re: HOTMOPR] #1366138
01/21/13 11:41 PM
01/21/13 11:41 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you have an air gap between the arm and pump lever at idle, thats wrong. no air gap.
Re: holley 750 vac issues [Re: lewtot184] #1366139
01/22/13 12:09 AM
01/22/13 12:09 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
flip the carb over..there is a set screw that allows the rear throttle blades to be opened to help with the idle..see if some one has opened them up too much...
Tony
70 AARCuda Vitamin C
Re: holley 750 vac issues [Re: 70AARcuda] #1366140
01/22/13 12:11 AM
01/22/13 12:11 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
No air gap and this 850 doesnt have the secondary idle adjustment..
