holley 750 vac issues
#1366121
01/07/13 10:51 PM
01/07/13 10:51 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Ive never really dinked around with vacuum secondary carbs much. I just went through one for my 63 413 4 speed. It idles and starts good but has a cruise stumble. When cruising steady throttle at 2000 rpms and I try excellerating slowly it cuts out. If I mash it it goes. Its that mid rpm cruising range that seems to be the problem..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: holley 750 vac issues
[Re: MR_P_BODY]
#1366123
01/07/13 11:35 PM
01/07/13 11:35 PM
HOTMOPR
Oakville, Wa
I have the pump arm gap at .015
[Re: BSB67]
#1366125
01/07/13 11:51 PM
01/07/13 11:51 PM
HOTMOPR
Oakville, Wa
yes its a 3310. I had it all apart and it was cleaned and reassembled.
[Re: HOTMOPR]
#1366126
01/08/13 12:10 AM
01/08/13 12:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you good getting up to cruise and then it wont take any pedal... could be your secondary is opening to easy... put a slightly stiffer spring in it
[Re: MR_P_BODY]
#1366127
01/08/13 12:57 AM
01/08/13 12:57 AM
HOTMOPR
Oakville, Wa
It seems to stumble at lower rpms. Unfortunatly The weather has been crappy and I havent had much chance to drive it since I got it running. It runs great in the shop. Idle and throttle response is great but under load its a different story.
[Re: HOTMOPR]
#1366128
01/08/13 01:03 AM
01/08/13 01:03 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I had that problem. I went up to the next size squirter and adjusted the pump screw to let it squirt sooner..
I am truckless..
[Re: 340SHORTY]
#1366129
01/08/13 01:11 AM
01/08/13 01:11 AM
HOTMOPR
Oakville, Wa
I thought about trying a bigger squirter. I guess I'll try closing up that pump gap also since Mr p mentioned that too. I know bigger squirters helped my starting line bog on my 980 double pumper..
[Re: HOTMOPR]
#1366133
01/08/13 04:39 PM
01/08/13 04:39 PM
MR_P_BODY
Also make sure you have enough timing
[Re: Dragula]
#1366135
01/08/13 05:46 PM
01/08/13 05:46 PM
Guitar Jones
On Mopar's a vacuum carb should never be used...But it also sounds like you squirter shot is a little late or small or both.
Uh why? I've used vacuum sec carbs for years on my race car to slow it down. A screw and a lock nut on the vacuum pod cap stops the opening very well.
[Re: HOTMOPR]
#1366137
01/21/13 11:33 PM
01/21/13 11:33 PM
HOTMOPR
Oakville, Wa
PUNTING!! I give up on the 750! I went back to my 850 dbl pumper. Problem I am having with this carb is I cant get it to idle down. I welded up the drilled primary throttle blades. The secondaries are not drilled and it doesnt have the secondary idle adjustment. Right now the best I can get it is 1100 rpms. Which might be fine in a auto with a bigger cam but the 4 speed likes about 800. Any ideas why it wont idle down. No cables were hooked up so nothing is binding. blades appear to be closed when looking down inside.. I also sprayed carb cleaner around it and no vacuum leaks.. Any Ideas?
[Re: HOTMOPR]
#1366138
01/21/13 11:41 PM
01/21/13 11:41 PM
Posts: 3,916 usa
lewtot184
usa
if you have an air gap between the arm and pump lever at idle, thats wrong. no air gap.
[Re: lewtot184]
#1366139
01/22/13 12:09 AM
01/22/13 12:09 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
flip the carb over..there is a set screw that allows the rear throttle blades to be opened to help with the idle..see if some one has opened them up too much...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1366140
01/22/13 12:11 AM
01/22/13 12:11 AM
HOTMOPR
Oakville, Wa
No air gap and this 850 doesnt have the secondary idle adjustment..
