Build sheet preservation. #1365988
01/07/13 03:06 PM
01/07/13 03:06 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I got a fairly nice (for its age) build sheet for my new '69 Bee. What is the best way to preserve it so it doesn't deteriorate farther? I have it folded up in a dictionary right now. Kidding, only kidding!
I thought of putting it in a picture frame with the original, and kinda ratty(still legible) fender tag. But then again, I'm a little wary of making a repop tag when I have the original, just for a display purpose.
Anyway, I hijacked my own thread. Any suggestions?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Build sheet preservation. [Re: OhioMopar] #1365989
01/07/13 03:07 PM
01/07/13 03:07 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Sheet
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Build sheet preservation. [Re: OhioMopar] #1365990
01/07/13 03:08 PM
01/07/13 03:08 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Tag
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Build sheet preservation. [Re: OhioMopar] #1365991
01/07/13 03:29 PM
01/07/13 03:29 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
The best think to do with a BS is to put it in an acid proof cover and store it in a dark, humidity controlled space somewhere where it won't get lost.
If you put it in a display frame, it will deteriorate due to UV but if you decide to do that you can buy UV rated glass for the frame to help. Depends whether it's in a frame to display a few times a year or if it's on your wall somewhere.
...the tag is a tough one, but I'd paint it and use it as-is I think.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Build sheet preservation. [Re: DPelletier] #1365992
01/07/13 03:57 PM
01/07/13 03:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=7505166&an=0&page=0
Also, keep looking. You may find one or more in better condition & possibly one or two for other peoples cars due to how the sub-assembly lines were run at the plants.
Re: Build sheet preservation. [Re: Alaskan_TA] #1365993
01/07/13 04:07 PM
01/07/13 04:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
As Barry said
Bottom line? DON'T LAMINATE IT!
Re: Build sheet preservation. [Re: DPelletier] #1365994
01/07/13 04:27 PM
01/07/13 04:27 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Thanks guys.
Dave, good point on the framing of it. I had just thought of that.
The only qualms about cleaning the tag up was that making it ready for a coat of paint would hurt it more. I guess a light soda blasting would clean the paint up.
I will look through the other thread. Thanks for the link.
Barry, will keep looking. Where do I send the things if I find more? Do you cover all models, or just T/A's? Would the best thing to do be posting it up here in the lost and found section?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Build sheet preservation. [Re: OhioMopar] #1365995
01/07/13 04:33 PM
01/07/13 04:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That is up to you. The found section is available here if you want to keep whatever you find until the matching car surfaces.
HH has over 7700 items for all kinds of different Mopars listed by VIN so folks can look for their own VIN there. I do require that the actual item(s) be sent in though. See http://www.hamtramck-historical.com/found.shtml
For your display purposes make a color scan & print out as many as you need. Keep at least one copy handy so you do not have to handle the original any more than needed.
Re: Build sheet preservation. [Re: Alaskan_TA] #1365996
01/07/13 04:37 PM
01/07/13 04:37 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Sending what(if) I find it isn't a problem. I would rather see It go to someone who has the right 'connections' to forward it in case someone needs it.
Good idea on the scan. Thanks!
Re: Build sheet preservation. [Re: OhioMopar] #1365997
01/07/13 05:33 PM
01/07/13 05:33 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I laminated the one for my GTX 25 years ago and have never regretted it. It is as pristine as the day I did it. Overall, I doubt that any other method would have worked as well.
Re: Build sheet preservation. [Re: 6PakBee] #1365998
01/07/13 05:51 PM
01/07/13 05:51 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
The previous owner of my 73 Challenger had the build sheet for it laminated. It looks real nice. It was done atleast 7 or 8 years ago.
Re: Build sheet preservation. [Re: OhioMopar] #1365999
01/07/13 08:34 PM
01/07/13 08:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Never laminate a buildsheet . In time it can damage the sheet, and
limits the ability to perform authinticity tests on the sheet if the need ever arises
. The only case I could see for lamination, is if the sheet is very deteriorated, fragmented, etc. and it may be the best way to keep it all together .
Greg
That's the biggest reason not to laminate it. The idea behind preserving a broadcast sheet is to preserve it, not to make it "pretty". What counts is the ability to determine if it's real in a land of fakes, and to be able to read the information on it. Condition is what it is, leave it alone, make a color scan for show and tell, stabilize it in a protective sheet, store it properly, done.
Re: Build sheet preservation. [Re: ScottSmith_Harms] #1366000
01/07/13 09:47 PM
01/07/13 09:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I too,have had mine in laminate for over 20 years...
The thought was preservation, and strength of a paper document that was 20+ years old...
I can attest to its authenticity because I'm the one who pulled it out of the seat springs...
It looks the same today as it did when I covered it...
Re: Build sheet preservation. [Re: RSNOMO] #1366001
01/08/13 01:36 AM
01/08/13 01:36 AM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
The most dangerous enemy is being exposed to the air. I sealed mine in a baggy. Easily stored with my other documentation and protects against deterioration. It's also accessible for authentication.
I made a photocopy for display purposes.
Re: Build sheet preservation. [Re: ScottSmith_Harms] #1366002
01/08/13 01:38 PM
01/08/13 01:38 PM
DPelletier Offline
DPelletier  Offline
Greg
I wouldn't laminate. My sheet is kept clean, dry and away from UV light and I have a half dozen hi-res color photocopies to use at shows or whatever. The sheet is mint and if it has survived the last 40 years stuck under the rear seat while the car sat in an unheated chicken coupe, I'm sure it will last another 40 the way it is now.
Re: Build sheet preservation. [Re: DPelletier] #1366003
01/08/13 01:57 PM
01/08/13 01:57 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
They didn't laminate the Declaration of Independence or other important documents. I wouldn't laminate my only original build sheet either.
If it is an important or rare car, you would want to retain the option of being able to prove the sheet is real. Also, there is no guarantee the plastic you cover the sheet in won't discolor or deteriorate over time. It is not reversable.
Obviously light and humidity are enemies. Keeping it in a stable environment and in an acid free sleeve is a good start.
Similarly with rare and collectible posters, you don't want to dry mount them as it is not reversible.
Re: Build sheet preservation. [Re: Aero426] #1366004
01/09/13 12:29 AM
01/09/13 12:29 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I found mine in the late 70's, and it's been in an acid-free sleeve now for the last 10 yrs. or so. Still in perfect condition now after 35 years, and I can slide it out of the sleeve any time I want.
Re: Build sheet preservation. [Re: ScottSmith_Harms] #1366005
01/10/13 10:57 PM
01/10/13 10:57 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
DOOH TO LATE !!! I laminated several around 1988 and fortunately they still look the same, the day it was done, thats been 25 years ago.
MLR426
