Need help from the newer car techs..... #136536
10/14/08 09:09 PM
10/14/08 09:09 PM
High Plains of South Dakota
O
olwhite64 Online content OP
olwhite64  Online Content OP
O
I don't know if I am posting this in the right area but I need to know where to hook up the green wire on an aftermarket tach on a 2001 Plymouth Neon. The wire would normally hook to the negative side of the coil on a car with a coil but this is a distributorless ignition. It has a coil pack mounted on the valve cover that all 4 plug wires hook to so I am thinking it might have to be 1 of those 3 wires that come from the harness and plug into that.
Not really a "race" post, sorry. Thanks in advance.
olwhite64
Re: Need help from the newer car techs..... [Re: olwhite64] #136537
10/14/08 09:39 PM
10/14/08 09:39 PM
O
O
*sniff* "please?"
Re: Need help from the newer car techs..... [Re: olwhite64] #136538
10/14/08 09:46 PM
10/14/08 09:46 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
The three wire on your coil are power and two driver wires. I think. but have not try it but I would try one of the driver wires. they are just pluse grounds for the coil. Just like any coil.Going off the top of my head you should have a green wire ? that would be the power.
Re: Need help from the newer car techs..... [Re: VernMotor] #136539
10/14/08 09:50 PM
10/14/08 09:50 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
IGNITION COIL - BLACK 3 WAY CAV CIRCUIT FUNCTION
1 K17 18DB/TN IGNITION COIL NO. 2 DRIVER
2 A142 18DG/OR power
3 K19 18BK/GY IGNITION COIL NO. 1 DRIVER
Re: Need help from the newer car techs..... [Re: VernMotor] #136540
10/14/08 10:45 PM
10/14/08 10:45 PM
O
O
Thanks, I will try to hook it up tomorrow.
