Replacing a heater core on a 1969 B-Body #1365208
01/06/13 04:06 PM
01/06/13 04:06 PM
Cottage Grove, MN
K
kurtsdodge Offline OP
K
Cottage Grove, MN
Does anyone have any cool tricks to R&R a heater core on a 1969
Dodge Coronet.
Re: Replacing a heater core on a 1969 B-Body [Re: kurtsdodge] #1365209
01/06/13 04:44 PM
01/06/13 04:44 PM
Remove the assembly, remove the retaining clips and replace the core If it is air conditioning car it is harder
Re: Replacing a heater core on a 1969 B-Body [Re: Cab_Burge] #1365210
01/06/13 05:15 PM
01/06/13 05:15 PM
Cottage Grove, MN
K
K
Cottage Grove, MN
Non A/C car. Looks like a great Sunday project.
Re: Replacing a heater core on a 1969 B-Body [Re: Cab_Burge] #1365211
01/06/13 05:56 PM
01/06/13 05:56 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that reply is accurate and hysterical rolled into one!
Re: Replacing a heater core on a 1969 B-Body [Re: mikemee1331] #1365212
01/06/13 06:26 PM
01/06/13 06:26 PM
Cottage Grove, MN
K
K
Cottage Grove, MN
And my comment was far from looking forward to the task at hand
And I will have a
Re: Replacing a heater core on a 1969 B-Body [Re: kurtsdodge] #1365213
01/06/13 06:41 PM
01/06/13 06:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
And I will have a
HaHaHa!! i too need to break down and do this too. mine doesn't leak but at 40+years, it's a coming!
Re: Replacing a heater core on a 1969 B-Body [Re: mikemee1331] #1365214
01/06/13 06:53 PM
01/06/13 06:53 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
why would you need a heater
Re: Replacing a heater core on a 1969 B-Body [Re: bonefish] #1365215
01/06/13 07:04 PM
01/06/13 07:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
to keep my Pop-Tarts warm, of course!
Re: Replacing a heater core on a 1969 B-Body [Re: kurtsdodge] #1365216
01/06/13 07:32 PM
01/06/13 07:32 PM
oklahoma
69suprbee Offline
69suprbee  Offline
oklahoma
I had to replace the heater core on my 69 bee with ac.didnt pull out the whole box.what I can tell you it's just figuring out how it all comes apart and goes back together.not as bad as it sounds.take pictures as you go.david
Re: Replacing a heater core on a 1969 B-Body [Re: kurtsdodge] #1365217
01/06/13 08:20 PM
01/06/13 08:20 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Shove corks into the nipples if the car has carpet and you wanna keep glycol off.
Rick
Re: Replacing a heater core on a 1969 B-Body [Re: Rick_Ehrenberg] #1365218
01/07/13 12:39 AM
01/07/13 12:39 AM
Rick
I should have added blow the heater core out if it hasn't already leak all the contents out
Re: Replacing a heater core on a 1969 B-Body [Re: Cab_Burge] #1365219
01/07/13 03:27 AM
01/07/13 03:27 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Go through all this and then hope that your new one fits. I got one from O'Reilys and the tubes didnt stick far enough through the firewall. Went to local radiator shop and got quoted a ridiculous price for him to lengthen them. I didn't feel like moving them around much and possibly breaking them, so I ordered from year one. Same manufacturer, 2 or 3x more expensive, and it still didn't fit right.
Re: Replacing a heater core on a 1969 B-Body [Re: kurtsdodge] #1365220
01/07/13 03:50 AM
01/07/13 03:50 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It's pretty easy to remove the non-AC box.
I believe I got my heater core from Autozone, about 15 years ago. I also picked up some thin foam and weatherstrip adhesive and made/replaced the seals. I think some of the restoration places sell a kit with the door seals and such to rebuild the heater box. It has been awhile, but I don't recall the '69 box having clips (my '71 box did?) I think the '69 box has a metal back that is screwed onto the box.
Re: Replacing a heater core on a 1969 B-Body [Re: 451Mopar] #1365221
01/07/13 04:57 AM
01/07/13 04:57 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Just lots of screws I believe. Here's a kit if you're feeling ambitious (moparts sponsors site). http://www.detroitmuscletechnologies.com/b-body/
Re: Replacing a heater core on a 1969 B-Body [Re: kurtsdodge] #1365222
01/07/13 11:33 AM
01/07/13 11:33 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
I've done 3.
I always order the complete gasket kit from a Moparts sponsor. Always fits.
I always order the cores from Rockauto.
I always have a hand vacuum pump and I check operation of all doors after the rbuild to make sure no glue/gaskets inhibit movement.
Not hard.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: Replacing a heater core on a 1969 B-Body [Re: 68KillerBee] #1365223
01/07/13 01:22 PM
01/07/13 01:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I had a similar experience with the heater core for my 68 Coronet, also the aftermarket blower motor didn't fit right... Took the core & the motor back & watched Ebay till an NOS blower motor popped up... On the heater core & bought one through my local radiator shop & when the tubes were to short I took it back & they extended them at no charge...
Re: Replacing a heater core on a 1969 B-Body [Re: 1_WILD_RT] #1365224
01/09/13 07:21 PM
01/09/13 07:21 PM
Cottage Grove, MN
K
K
Cottage Grove, MN
Thanks everyone! I started the project on Sunday. I will finish today.
A lot of other pressing things, can't drive the car until March
