Indy 360-3 intake T-Stat housing #1365072
01/06/13 11:20 AM
01/06/13 11:20 AM
New Mexico
Adobedude Offline OP
New Mexico
Posted this in Q&A, no response.
I'm swapping from an M1 to an Indy Intake on my Magnum based 408, what T-Stat housing is going to fit? One from an LA intake?
Bolt center on the Indy is 3.25".
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Indy 360-3 intake T-Stat housing [Re: Adobedude] #1365073
01/06/13 12:22 PM
01/06/13 12:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I used a regular chrome mopar housing on mine, which everyone said would leak but it hasn't
Re: Indy 360-3 intake T-Stat housing [Re: Adobedude] #1365074
01/06/13 12:35 PM
01/06/13 12:35 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I'm using this on my Indy 360-14-3r intake. No leaky chrome. http://chucker54.stores.yahoo.net/mabialwane.html
"Just a Bracket car dressed up like a streetcar"
Re: Indy 360-3 intake T-Stat housing [Re: Just-a-dart] #1365075
01/06/13 01:26 PM
01/06/13 01:26 PM
New Mexico
New Mexico
440 Source makes a billetz one too for 25.00, but I don't know the bolt spread. Guess it's the same for early LA and big blocks, 3.25".
http://store.440source.com/prodinfo.asp?number=114-1004
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Indy 360-3 intake T-Stat housing [Re: Adobedude] #1365076
01/06/13 01:45 PM
01/06/13 01:45 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Its the same exact as a sb chevy.The mopar ones leak unless you use the one w an oring.
Re: Indy 360-3 intake T-Stat housing [Re: Just-a-dart] #1365077
01/06/13 01:46 PM
01/06/13 01:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats pretty much what i have,but chrome steel
Re: Indy 360-3 intake T-Stat housing [Re: fishy340] #1365078
01/06/13 01:54 PM
01/06/13 01:54 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Andy, do the chevy ones come with an o-ring?
Re: Indy 360-3 intake T-Stat housing [Re: mshred] #1365079
01/06/13 01:59 PM
01/06/13 01:59 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I had the mr gasket one and it was fine no leaks and cheap.I bought a black csr one w the swivel so i could aim it and match the color of my motor.The csr one does have an oring.Neither leak.
Re: Indy 360-3 intake T-Stat housing [Re: fishy340] #1365080
01/06/13 01:59 PM
01/06/13 01:59 PM
Toronto
mshred Offline
mshred  Offline
Toronto
And those were for small chevy's right?
Re: Indy 360-3 intake T-Stat housing [Re: mshred] #1365081
01/06/13 02:04 PM
01/06/13 02:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Yes sb gm is exactly the same
Re: Indy 360-3 intake T-Stat housing [Re: fishy340] #1365082
01/06/13 02:12 PM
01/06/13 02:12 PM
Toronto
mshred Offline
mshred  Offline
Toronto
cool thanks man!
Re: Indy 360-3 intake T-Stat housing [Re: fishy340] #1365083
01/06/13 02:18 PM
01/06/13 02:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
dang fishy I better go tall mine that. it's been on about 4 years and not a drop
Re: Indy 360-3 intake T-Stat housing [Re: Quicktree] #1365084
01/06/13 02:35 PM
01/06/13 02:35 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
U sure its a mp performance one or the so called billet one mancini sells for a sm fortune? Because in my household theres no less then 13 mopars..and the crap one mopar sells is just.that even w rtv.
Re: Indy 360-3 intake T-Stat housing [Re: fishy340] #1365085
01/06/13 03:03 PM
01/06/13 03:03 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
I have one from mancini I cound'nt get it seaded even with doubl gaskets with and without rtv. I now have a good one with an o-ring. no leaks.
Re: Indy 360-3 intake T-Stat housing [Re: fishy340] #1365086
01/06/13 03:30 PM
01/06/13 03:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea it was a mp, but I cleaned up the mating surface with a flat file.
Re: Indy 360-3 intake T-Stat housing [Re: Quicktree] #1365087
01/06/13 03:57 PM
01/06/13 03:57 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Ive heard that its the chrome on the face of the mating surface that causes the leaks, not the neck itself.
Re: Indy 360-3 intake T-Stat housing [Re: Quicktree] #1365088
01/06/13 03:57 PM
01/06/13 03:57 PM
BPE Offline
BPE  Offline
They will interchange, but if you plan to run a thermostat that's where they are different. IIRC the mopar housing has a relief for the thermostat and the SBC has relief milled into the intake.
Rod
Re: Indy 360-3 intake T-Stat housing [Re: BPE] #1365089
01/06/13 03:59 PM
01/06/13 03:59 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Rod
Good info Rod! I am running a t-stat, so I guess I will have to stay with the leaky stuff....My Mr. Gasket mopar one needed a ton of RTV to finally not leak
Re: Indy 360-3 intake T-Stat housing [Re: BPE] #1365090
01/06/13 04:12 PM
01/06/13 04:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Rod
correct
Re: Indy 360-3 intake T-Stat housing [Re: Quicktree] #1365091
01/06/13 04:59 PM
01/06/13 04:59 PM
Mt Morris Michigan
Mt Morris Michigan
Mine leaked because it would warp. I had two and filed them flat on a regular basis. They were mounted with studs and torqued to spec. They warped anyway. Bought the o-ringed neck and no leaks to date. Been 4 years now.
