Indy 360-3 intake T-Stat housing
#1365072
01/06/13 11:20 AM
01/06/13 11:20 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Posted this in Q&A, no response.
I'm swapping from an M1 to an Indy Intake on my Magnum based 408, what T-Stat housing is going to fit? One from an LA intake?
Bolt center on the Indy is 3.25".
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: Indy 360-3 intake T-Stat housing
[Re: fishy340]
#1365078
01/06/13 01:54 PM
01/06/13 01:54 PM
Posts: 3,415 Toronto
mshred
Toronto
Its the same exact as a sb chevy.The mopar ones leak unless you use the one w an oring.
Andy, do the chevy ones come with an o-ring?
[Re: fishy340]
#1365080
01/06/13 01:59 PM
01/06/13 01:59 PM
mshred
Toronto
I had the mr gasket one and it was fine no leaks and cheap.I bought a black csr one w the swivel so i could aim it and match the color of my motor.The csr one does have an oring.Neither leak.
And those were for small chevy's right?
[Re: fishy340]
#1365082
01/06/13 02:12 PM
01/06/13 02:12 PM
mshred
Toronto
Yes sb gm is exactly the same
cool thanks man!
[Re: fishy340]
#1365083
01/06/13 02:18 PM
01/06/13 02:18 PM
Quicktree
dang fishy I better go tall mine that. it's been on about 4 years and not a drop
[Re: fishy340]
#1365086
01/06/13 03:30 PM
01/06/13 03:30 PM
Quicktree
U sure its a mp performance one or the so called billet one mancini sells for a sm fortune? Because in my household theres no less then 13 mopars..and the crap one mopar sells is just.that even w rtv.
yea it was a mp, but I cleaned up the mating surface with a flat file.
[Re: Quicktree]
#1365087
01/06/13 03:57 PM
01/06/13 03:57 PM
Posts: 3,395 Pa
Hot 340
Pa
Ive heard that its the chrome on the face of the mating surface that causes the leaks, not the neck itself.
[Re: BPE]
#1365089
01/06/13 03:59 PM
01/06/13 03:59 PM
mshred
Toronto
They will interchange, but if you plan to run a thermostat that's where they are different. IIRC the mopar housing has a relief for the thermostat and the SBC has relief milled into the intake.
Rod
Good info Rod! I am running a t-stat, so I guess I will have to stay with the leaky stuff....My Mr. Gasket mopar one needed a ton of RTV to finally not leak
[Re: BPE]
#1365090
01/06/13 04:12 PM
01/06/13 04:12 PM
Quicktree
Rod
correct
